Old 03-02-2016, 02:38 AM   #1
mancad
Gasket remover
I'm trying to remove the old paper gaskets under the access covers on the side of the 4spd xmission on my C20. I had some old NAPA spray gasket remover that worked pretty well, but they don't sell it anymore. I tried Permatex remover. It is better than nothing, but not much. Any recommendations?
mancad is offline   Reply With Quote
Old 03-02-2016, 03:59 AM   #2
'68 Newtricks
'68 Newtricks's Avatar
Re: Gasket remover
razor blade? Scrape scrape scrape
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 03-02-2016, 10:22 AM   #3
snipescastle2
snipescastle2's Avatar
Talking Re: Gasket remover
I've used those "Scotchbrite Roloc Disks" with an angle die grinder, just use the medium or fine grit stuff, I think its gray or blue in color.you don't want to dwell in the same area too long, it will remove metal if you do.
Just a recommendation.
Ben
snipescastle2 is offline   Reply With Quote
Old 03-02-2016, 11:28 AM   #4
100%Chevy
Re: Gasket remover
Wire wheel on a 4" grinder does it for me!
Mike.
100%Chevy is offline   Reply With Quote
Old 03-02-2016, 02:31 PM   #5
Gromit
Re: Gasket remover
I've had good results using a heat gun to soften the gasket and its adhesive and permit easier scraping but not in a confined space where plastic or rubber parts are nearby or especially where there are automotive oils or fuel of course..
Gromit is offline   Reply With Quote
Old 03-02-2016, 02:52 PM   #6
Davidf
Re: Gasket remover
Mike.
...until a piece of wire from the wheel ends up it the case/engine/whatever...scary. I am in the razor blade crowd. But, on most of the car shows, you see them using die/angle grinders with what is probably scotch-brite pads. For me, that is uncontrolled debris flying everywhere.
Davidf is offline   Reply With Quote
Old 03-02-2016, 03:19 PM   #7
DarkFlounder
Re: Gasket remover
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline   Reply With Quote
Old 03-02-2016, 03:22 PM   #8
Davidf
Re: Gasket remover
I have a "gasket scraper" tool in my tool box (see above), but generally it only gets used to scrap grease from parts I am cleaning up. Not sharp enough for most gasket removal tasks.
Old 03-02-2016, 08:15 PM   #9
GRX
GRX's Avatar
Re: Gasket remover
Originally Posted by DarkFlounder View Post
That ^^^ easily sharpened on a bench grinder.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-02-2016, 08:21 PM   #10
68panelman
68panelman's Avatar
Re: Gasket remover
Razer blades always worked for me
68panelman is offline   Reply With Quote
Old 03-02-2016, 09:48 PM   #11
mancad
Re: Gasket remover
Thanks for all the thoughtful responses. I ended up using a single edge razor blade. There was enough room to get to it.
Old 03-03-2016, 01:28 AM   #12
Re: Gasket remover
Elbow grease never let me down
