03-02-2016, 01:02 PM | #1 |
1969 GMC Stepside SWB Tranny/Rear End Choices
I'm looking to purchase a tranny & rear end from the stock set up I have now on my truck. Just looking to do minimal work and just pretty much plug n play to what I've got in it...what set up do ya'll recommend with a chevy 350ci (crate engine) w/Holley650 set up with a mild cam. I want to have this done soon and with the least work/parts to buy and just replace those two things.
I just want to be able to get rid of the granny gear, and have a posi in this truck. what bugs me the most is the feeling of not putting the power down to the ground and truck just feels sluggish and I can't but think that it's because the engine has been upgraded but the rest of the drive train isn't. I know I'll need to upgrade suspension soon too...I'm coming from vw's so just bare with my questions as I'm still learning from you guys here on the board. Are there newer truck set ups that would just bolt on with minimal work? All your guys help/rec's are greatly appreciated.
"If you aint first your last!!" 1969 GMC C1500 Stepside Shortbed - daily driver Mando |
03-03-2016, 10:22 AM | #2 |
Re: 1969 GMC Stepside SWB Tranny/Rear End Choices
tranny options are limited when stayin manual.
the granny 4 is a good stout trans that will handle alot more power than most other trannys. just about any other trans will require a driveshaft change or just getting yours shortened plus a few other changes. 3spd manual(overdive optional) saginaw/muncie/t10 4spd a833 4spd tremac 5/6 speed t56 6 spd nv3500/4500 5 spd richmond these are just off the top of my head some are better than others and there are other trans out there that will work you just gotta ask yourself what you really want.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
03-03-2016, 02:28 PM | #3 | |
Anyone out in the LA or San Fernando Valley know of any reputable shops that can help with this type of work?
03-03-2016, 06:11 PM | #4 |
The M22 is a LOUSY street transmission. Yes, it is strong due to the reduced angle on the gear sets and, along with the M21, shares the distinction of being the closest ratio factory 4 speed transmission ever. Oh, and it's expensive because GM didn't make that many of them and they were only used in the much more rare powertrain vehicles. *(optional in big block Camaros and Z/28s, 454 Chevelles, Big Block 'vettes, etc)
These things make it loud and wanting 4.88 gears to run around town, and obviously that would be unacceptable for no-overdrive on the highway. And there are WAY more M22's for sale than they actually made. Usually because people think thats what they have because they don't know how to tell. The 2.20 first gear of the M21/M22 really are best suited for restorations or track cars. The M20 is a better choice since you can run 3.30-3.90 gears for acceptable performance. But the granny 4 speed is a better transmission for the truck that will occasionally be used as a truck. If you are building a hot rod you want to drive, look into an M20 or a wide or extra wide ratio Borg Warner Super T10. The 2.64 T10 and a set of 3.73 would be pretty nice.
03-04-2016, 02:42 PM | #5 | |
