Old 03-02-2016, 01:14 PM   #1
sharkskinman
correct stock piston for a 230??
http://m.ebay.com/itm/311383036329
Or
http://m.ebay.com/itm/311253977358
Just need 1 for 230 replacement
1 states 1/16 ring instead of 5/16??
sharkskinman is offline   Reply With Quote
Old 03-02-2016, 01:19 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: correct stock piston for a 230??
Your engine a 230 or a 250? Both pistons mentioned are for 250's but I'm wanting to be sure. lol
Old 03-02-2016, 03:33 PM   #3
sharkskinman
It's a 230 but these are the only ones I've seen correct with D on the flat top
Were 230 pistons different and do I have a 250? I'm pretty sure it's a 230 unless it was end of 65 model year that they put in 250s
Old 03-02-2016, 03:47 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
I've never actually gotten a "fact" label on this, but I believe 230 pistons were flat tops. 250's and 292's used the .300 dish pistons. If you can get me an engine number from the block I may be able to decode it. Unless you have already.
Old 03-02-2016, 04:42 PM   #5
sharkskinman
Block behind motor mount ..3877178 GM 48... Chevrolet / Buick / Oldsmobile / Pontiac / GMC 230, 250 62 – 78
Head between #1-#2 ..4886F7
Intake..385938 GM 17
Old 03-02-2016, 04:50 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
I'm leaning towards a 250. Bores are the same for both engines, but strokes are different. The 250 being longer. The 230 has a taller compression height of 1.795 as to the 250 at 1.655. That's why I'm also sure the 230 has flat tops. I'm thinking yours is a 250. Let me make a call to a fellow inliner and I'll get a for sure answer.
Old 03-02-2016, 05:03 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
You have a 250 and you'll want the piston with the 5/16 rings. The 230 has a flat top with valve reliefs and the 250 has the dish piston. If you were to put 250 pistons in a 230 your compression would drop. The piston with the 1/16 ring must be a newer design or something. My racing pistons in my 292 have that same ring size.
Old 03-02-2016, 07:51 PM   #8
sharkskinman
crazy! all ive read says 250 wasnt in the 65 pickup
guess ill be looking for one of those then
with head off can you measure at TDC from piston to head surface to determine stroke?
or to measure anything of value?
Old 03-02-2016, 09:44 PM   #9
Lugnutz65
Lugnutz65's Avatar
You are correct. The 1965 C10 did not have a 250ci. If you need 230 pistons, I have 6 230 pistons that I saved from my 1965 230ci. You are welcome to have them all or however many you want - FREE. Send me a PM. I can post a picture of my 230 pistons if you want me to.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-02-2016, 09:49 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
Yeah, measure from the top of the piston to the top of the cylinder and that'll get you pertty close.
250 stroke is 3.530
230 stroke is 3.250
So estimate 3 and a 1/2 or 3 and a 1/4.
Anyone could have changed the motor out through the years.
Old 03-03-2016, 02:01 AM   #11
sharkskinman
Piston in question
Do the ones you have look like this?
This style I mean��
Old 03-03-2016, 02:33 AM   #12
GRX
GRX's Avatar
Since you have the head off. Just measure distance from deck to piston at bottom of the stroke.
230 = 3.250" ... 250 = 3.530"
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-03-2016, 02:46 AM   #13
sharkskinman
Had
Old 03-03-2016, 07:03 AM   #14
Lugnutz65
Lugnutz65's Avatar
Piston in question
This style I mean��
These came out of my 230ci. You are welcome to have them but they do not look like yours.
Old 03-03-2016, 11:24 AM   #15
TJ's Chevy
TJ's Chevy's Avatar
Boy my curiosity is peaked now.....wonder if using 230 pistons in a 250 would boost compression. Rod length may need to be changed, but I haven't heard of anyone doing it yet.
Old 03-03-2016, 02:49 PM   #16
Lugnutz65
Lugnutz65's Avatar
I was gonna get a 250 built. Everyone said to use 307 flat top pistons and deck the head and go bigger valves. I got a practically new 230 for dirt cheap so budget minded common sense won over and I'll use the 230.
Old 03-03-2016, 04:01 PM   #17
sharkskinman
Going to get piston ring it put it in
Checking what I can, resealing what I can but nothing more at the moment
Old 03-03-2016, 04:57 PM   #18
TJ's Chevy
TJ's Chevy's Avatar
That's the one big advantage of the 250 is that 307 pistons. They are alot cheaper than the Ross pistons. lol
