Old 03-02-2016, 07:42 PM   #1
Chevy3+3
Swapping in hydraulic clutch pedals....what do I use for nuetral safety?
first of all my truck is an '88 V30 and was a factory auto truck. I am swapping in a set of period correct pedals and need some advice on setting up the neutral safety switch.
My original auto column has a switch at bottom of the column. It has 2, 2 wire plugs going to it. I'm guessing one is a neutral safety switch and a 2nd plug for the reverse lights. My first question is........is this really a neutral safety switch because the later model columns had an ignition switch interlock I thought not allowing the ignition switch rotate forward to start in gear. If that is true could this plug be intended for something else?
If it is in fact a neutral safety switch I had planned on using the wires and routing them to my clutch pedal switch to act as a neutral safety switch. Does anyone see a problem with this?
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 03-02-2016, 11:14 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Swapping in hydraulic clutch pedals....what do I use for nuetral safety?
One should be Neutral safety and one backup lamps.
That's how I'd do it.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-02-2016, 11:20 PM   #3
Chevy3+3
Well I will get that wired up as soon as I find the 4 pin pigtail that plugs into the clutch/nuetral safety switch, lol
Old 03-02-2016, 11:23 PM   #4
hatzie
Moderator
hatzie's Avatar
Honestly I ran my 1985 without the clutch interlock and never missed it.
Old 03-02-2016, 11:25 PM   #5
Chevy3+3
Since its a TBI truck and my daughter is 5 I would hate to have her hit the key and take off. I personally could live without it but I feel more comfortable knowing its there so an accident doesn't happen
Old 03-03-2016, 10:03 AM   #6
hatzie
Moderator
hatzie's Avatar
Two pins on the clutch switch are needed if you have cruise control.
Old 03-03-2016, 10:09 AM   #7
Chevy3+3
Thanks Hatzie. Check out this thread. See if you know
http://67-72chevytrucks.com/vboard/s...d.php?t=699703
Old 03-03-2016, 08:13 PM   #8
jetmech85
I am by no means a guru on the electrical systems on these trucks but I think you will find the neutral safety switch on yours only turns on the reverse lights and tells the computer that the transmission is in neutral. The neutral safety is a mechanical lock out built into the steering column. My non-computer '86 doesn't even have a wire on that terminal. My hydraulic clutch had the wires cut and wire nutted together, probably because the safety switch failed. I found a wire harness in a wrecking yard and swapped the cut wires for non cut ones and bought a new safety switch.
jetmech85 is offline   Reply With Quote
Old 03-03-2016, 10:08 PM   #9
Chevy3+3
I'm not an electrical guru either but I believe what you said would be correct
Old 03-06-2016, 10:39 PM   #10
bealaddison
bealaddison's Avatar
On a manual transmission it is referred to as a clutch pedal position switch. There is a connector with purple and yellow wires, if I remember correctly, that connects to the column on an automatic shift. To use it with a standard transmission, there is a pig-tail that runs from the wiring for the automatic and connects to the clutch pedal position switch mounted on the pedal assembly.
'87 Chevy V20 Suburban
6in Lift, 37in Toyos/Nittos on 17x9 KMC Diesels
2009 Chevy Silverado 2500HD
6in Lift, 35in Toyos on 20x9 KMC Monsters
bealaddison is offline   Reply With Quote
