Old 03-03-2016, 11:16 PM   #1
saon
flip kits
Reading up on axle flip kits for a '72 leaf spring rear. Some say to c-notch n some do not. Does anyone who installed them know What the distance is between the axle housing and spring with a kit installed? And did you c-notch it or not?
saon is offline   Reply With Quote
Old 03-04-2016, 01:08 AM   #2
cadillacart
1972 C/20
cadillacart's Avatar
Re: flip kits
I c-notched mine. not much travel otherwise.
Will try and find some pics tomorrow.
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 03-04-2016, 02:10 AM   #3
kwmech
Re: flip kits
If you go with a sprung under set-up, you will lower the truck about 5'' depending on the thickness of the leaf pack. You will need to notch the frame
Old 03-04-2016, 09:49 AM   #4
saon
Re: flip kits
wondering if I put in a lowering block, how thick of one I can use. I understand my c-notch can be big or small for clearance. but I was hoping for a 4 inch c notch,so not to cut the bed, and to use a 3 or 4 inch lowering block for a total of 8-9 inches of static drop. should leave me with 3 1/2-4 inches of travel. not sure its enough travel, if it wasn't I can always swap out a smaller block. that's why I was looking for the axle to spring distance on a flip kit bracket. looks like they may be 2 inches in addition to the 5 of the axle for a 7 ish total.
Old 03-04-2016, 02:27 PM   #5
KY_GMC
KY_GMC's Avatar
Re: flip kits
I put a flip kit on my truck when I was building it, and I did not c notch the frame.
It originally came with the HD spring package, which had 5 standard springs, and then 4 more on top.
I removed the 4 extra springs and left the standard ones. With the flip kit in, I had the standard bump stops on the axle and they nearly touched the frame while stationary. I had to cut around 2" off of them to get it to ride nicely. Kind of hard to see from this photo.
I haven't had anything in the back yet, so I don't know what it is going to be like with some weight on it.
I'm leery about cutting the frame and putting a c notch in. As a mechanical engineer, the analysis that I have seen state that there is no way to get the structural rigidity back unless you do the step notch. I wanted to keep the integrity of the frame so that I could still haul or tow.
In the end, it's totally your call.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 03-04-2016, 03:23 PM   #6
sanford66
sanford66's Avatar
Re: flip kits
Axle flip and c-notch in my 72. I have used it to move twice and still haul stuff in it occasionally, if you have it loaded down good it will bottom out sometimes. As for the c-notch I used a bolt in notch. The bolt in notch is actually made of thicker gauge steel than the truck frame is. Make sure you use good quality grade 8 bolts when you install it. I feel the section of the frame with the notch is stronger than original, but that's just me. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 03-04-2016, 08:26 PM   #7
Mike C
Mike C's Avatar
Re: flip kits
DJM flip on my HD spring equipped '69. Lowered it just over 7". I removed the bumpstop pads from the axle and put the DJM bumpers on the frame rail. About 2 1/2" clearance. It will hit if I hit sharp impacts at speed, but for the most part it does not hit hard at least.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-10-2016, 04:01 PM   #8
Low8lug
Low8lug's Avatar
Re: flip kits
Hey Sanford66 or cadillacart could you post a pic of you c notch with leaf springs I'm in the process of doing my flip kit on my 71 gmc c20 long bed. It looks like the frame is ganna sit on the axle.
Low8lug is offline   Reply With Quote
