Old 03-05-2016, 02:48 PM   #1
ranger danger
ranger danger's Avatar
More fuel capacity
My 69' Suburban has the OEM 21 gal. gas tank. I would really like to double the tank size. What are some of the ways that can get me there. I do not want to cut new filler necks into the body! I know of one company making a 40 gal tank but they are expensive! I've also heard of a "dealer installed" 45 gal tank. Where might I find one of these? Thanks
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 03-06-2016, 12:41 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: More fuel capacity
Finding a good original 40 gal tank might be a tall order. The one I took out of the '72 I parted out was in really bad shape.... There are (I think) 4 tubes that are welded into the tank that the mounting bolts go through. There were holes rusted through inside the tubes and it would have been almost impossible to fix them. You may get lucky and find a good one but I really doubt it.
LockDoc
Leon
Old 03-06-2016, 02:16 AM   #3
magicoolbus
magicoolbus's Avatar
I have an aux tank in my suburban that was made by Travel Tanks, a California company long out of business. It is designed to go under the middle seat. It is a basic welded up steel box that is plastic lined and has given me no trouble for the 20 years I have had it. Picture of label below.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 03-06-2016, 03:04 AM   #4
CG
BlahBlahBlah
Board member here put in a late model tank in his burb, but I can only remember his real name (no help I know). Let me think about this and see if I can figure it out and find a link.
Ok I found the link and it turns out he didn't use the tank he had a custom one built. He got the idea from this thread though, post #17
http://67-72chevytrucks.com/vboard/s...d.php?t=520146
Old 03-06-2016, 10:32 AM   #5
ranger danger
Thank you sir, that's the kind of stuff I'm looking for!
NRA Life Member
Old 03-06-2016, 10:19 PM   #6
notchbackgta
I just put one in from an 87 Suburban because I wanted an in-tank pump, but the earlier ones are similar 40 gallon with senders for the carburetor
notchbackgta is offline   Reply With Quote
Old 03-07-2016, 02:51 AM   #7
60sIron
60sIron's Avatar
Mine came with the middle seat bolted to it, as already posted. Rubber hose with a grommet and cap on the drivers side. The filler looked bad. But more importantly very unsafe. I can hear the screaming........ But no one can tell me that a fuel tank in the passenger compartment with a filler that can easily be torn off in an accident or roll over is safe.
60sIron is offline   Reply With Quote
Old 03-07-2016, 07:50 AM   #8
ranger danger
Aero Tank has a replacement 40 gal. tank but $525!?
http://www.aerotanks.com/inventory/1139.html
NRA Life Member
Old 03-07-2016, 09:02 AM   #9
Bigdav160
Bigdav160's Avatar
I used a early nineties square body Suburban 40 gallon tank.
It fits like like a glove.
I did have to add a crossmember (and relocate another) to make the support straps fit.
I also moved the filler neck to the corner to align with filler tube. With some fancy piping, you might be able to get away from the filler neck relocation task.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-08-2016, 12:54 PM   #10
notchbackgta
I used a 45 and a 90 elbow with a reducer to adapt from the smaller of the body to the larger of the tank and keep the stock location
Old 03-09-2016, 04:43 PM   #11
rocknss
rocknss's Avatar
Do you have part numbers of the 45,90 and reducer you used and location were you found them. I'm looking into converting my Burb to EFI with a larger tank also.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 03-10-2016, 11:25 AM   #12
vectorit
What?
vectorit's Avatar
You can do what my Burb had for most of it's life, and that is to put 2 21 gallon tanks in it. The second one will fit right behind the existing one, and the fill tube was modified to be a Y pipe with one cap.
The fuel was diverted using a manual valve, and the fuel gauge was switched between the two with a toggle switch on the dash.
It worked good for many many years, and I only took it out because I was was restoring the truck to OE spec.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-10-2016, 03:46 PM   #13
ranger danger
A very interesting idea!! Rather than 2 fuel gauges, I would cap off the second tank sending unit and then put a 3/4" equalizer tube between the 2 tanks with a ball cock valve inbetween. That way you would always have the ability to shut off flow between them. Primarally, the fuel level would stay equal. Interesting....very interesting!!
NRA Life Member
Old 03-10-2016, 09:24 PM   #14
notchbackgta
Sorry, it was two 90's with a reducer adapter between them. Its a little under 1.5" at the filler and it 1.75" at the tank. I had to trim them both once I got the tank under there. I can try to take a picture tomorrow, if I remember. I got all the parts off Amazon
Gates 24716 Fuel Hose, 1-3/4" - 90 Degree
Gates 24715 Fuel Hose, 1-1/2" - 90 Degree
1.5" OD x 1.75" OD Step-Up Transition, 304... 1.5" OD x 1.75" OD Step-Up Transition, 304...
Old 03-21-2016, 09:17 PM   #15
infinite-foamies
LockDoc
It could be done I think depending on the ID of the tubes.
I am running a second factory tank behind the factory. I am running a trailer hitch which will also protect the tank in a rear end collision, but the hitch had to be pushed back such that the entire tube sticks out behind the bumper.
infinite-foamies is offline   Reply With Quote
