Old 03-08-2016, 01:15 AM   #226
DblTrbl
DblTrbl's Avatar
Re: My 83' Crew Cab Dually project
I added some crossbars in front and behind the tank and built some tank straps. I picked up a slip roller and press brake a few weeks ago and it makes things like this soooo much easier.
Oh...and I stabbed myself in the eyeball with a zip tie yesterday. It feels pretty awesome. ��
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 03-08-2016, 01:30 AM   #227
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
You shouldn't put acid in your eyes.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-08-2016, 01:35 PM   #228
daddyjeep
daddyjeep's Avatar
It's all fun and games until....well, someone gets stabbed in the eye with a zip tie. That looks a little tender. Since I have a permanently screwed up eye i can relate. My eye doc recommends "Tears Naturale" eye drops. There are no preservatives and apparently the preservatives in other drops are a bad thing.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-09-2016, 11:07 PM   #229
DblTrbl
DblTrbl's Avatar
Thanks for the tip, Dad...I found some and the eye seems to be getting a little better. It still hurts, but not the raw feeling that I had before.
I spent a little time today buttoning up unfinished things; filled the trans, wired the electric choke, wired up the electric cooling fans with the temp probe and tried to start the truck. It took several cranks (as expected to get the fuel lines primed) then it just backfired instead of starting. After a little problem solving, I realized that I had the distributor 180* off. Getting the distributor out with a 4" Z is a *****! I finally got it where it needs to be and tried again...it stumbled and fired up...ran like **** because I still need to time it and adjust the carb, but at least it's progress and I expect to have it running very soon. Nothing blew up, and no strange noises, so that should be a good sign.
I did notice when I ran the air up and down that the pinch welds are supporting the full weight of the truck when it's aired out which is concerning. I'm left with two options; add blocks to the bottom of the frame or get rid of the pinch welds. What is the method for doing the latter? Do they get folded in or just cut off. Cutting seems like it will compromise the structure of the rockers...
Instagram: lofab77
Old 03-09-2016, 11:40 PM   #230
ruffrida2005
You can get rid of the pinch one or two ways. Drag them off or cut them off. If you cut them. What I did with one of my trucks was cut a little at a time and weld it. That way you don't loose support. Also after its all welded but you don't think it doesnt enough support you can weld a strip of 1/8th strip to the bottom and add a 1/8th washer to your cab bushings to offset it.
Paul
Old 03-10-2016, 02:55 PM   #231
tinydb84
tinydb84's Avatar
I know a low of guys fold them (no cutting, welding, etc). I saw on the Cannonball C10 they cut and tig welded them. I don't have a pic of it but it does look much cleaner. I will probably do the same.
I honestly think I will lay a bit lower than the rocker. I think I am going to add either polyurethane bumpstops to the bottom of the frame and/or to the suspension. I don't want to scratch up all the nice paint I did underneath.
David
Instagram: myfabguy
Old 03-11-2016, 01:32 AM   #232
DblTrbl
DblTrbl's Avatar
Thanks fellas...I think I may try folding them in and see how that works to start. If I don't like it, I can always cut them off. I don't know about TIG welding overhead, contorted and on my back. Lol
Instagram: lofab77
Old 03-11-2016, 01:50 AM   #233
DblTrbl
DblTrbl's Avatar
Today's progress:
It runs! I love how the flowmasters sound.
http://youtu.be/VqdyG7pj9SQ
Nearly asphyxiated myself with all the smoke from the header paint burning off. Topped off all of the fluids, no leaks and the electric fans kicked on at temp.
Now that it runs, I can get it out of the garage and set the bed back on so I can get the floor cut out and raised. Figured I should actually paint the back half and permanently install all of my hard lines, tanks, compressors, etc. So, I pulled all of the suspension and the fuel tank and laid down some black and clear coat...
I'm still trying to work out how to do the shocks out back. I'm afraid that a cantilever may be my only option...
Instagram: lofab77
Old 03-11-2016, 10:23 AM   #234
aggie91
I'm just glad to be here!
aggie91's Avatar
Slick looking paint. I like how the "covers" look now that they are painted.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-12-2016, 03:20 PM   #235
54earl
54earl's Avatar
I also like how the paint looks. How is the eye?
54earl is offline   Reply With Quote
Old 03-12-2016, 04:00 PM   #236
DblTrbl
DblTrbl's Avatar
Thanks guys. Eye is feeling much better. Pride is still recovering, but that not the first time I've done something stupid...
Instagram: lofab77
Old 03-17-2016, 12:24 AM   #237
DblTrbl
DblTrbl's Avatar
Moving things along...
Still have to do some trimming on the inner fenders to get it to sit all the way down. I'm hoping I don't have to mess with the outer fenders at all. I'm not a fan of fiberglass work...
Instagram: lofab77
Old 03-23-2016, 08:24 PM   #238
DblTrbl
DblTrbl's Avatar
Trimmed and trimmed...and then some more trimming. Got the bed set correctly and it clears everything. Also hooked up the bags, tanks, etc. I even took it for a spin...across the yard.
It seems that since I'm running 15gal of tanks, the twin 480's are just not enough. It takes over 15 minutes to get up to pressure. I'm looking for suggestions on what to do.
I could:
1) add two more 480's
2) try to figure out a belt driven system
3) use the big ass inverter that I have and hook up a 120v compressor
4) ???
Thoughts?
Instagram: lofab77
Old 03-23-2016, 09:15 PM   #239
ruffrida2005
Your cheapest and fastest route would be running a york.
Paul
Old 03-23-2016, 09:49 PM   #240
COS399
COS399's Avatar
Looks great!
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 03-23-2016, 11:27 PM   #241
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: My 83' Crew Cab Dually project
i love how when its aired up it just looks like an average truck. then it just lays flat out
you could look into converting an AC compressor into an air compressor. i read up on it not too long ago just out of curiosity it looks fairly simple. you might even be able to run dual AC compressors as air compressors. theres more than a few threads on the web about the conversion.
you could also keep the 480s as backup.
TrailerTrash is offline   Reply With Quote
Old 03-28-2016, 01:38 PM   #242
slammed427
slammed427's Avatar
Looks great! Congrats bro!
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 04-01-2016, 01:49 AM   #243
DblTrbl
DblTrbl's Avatar
I've been tackling the bodywork lately. Man, this is a lot of truck! There were several old antenna mounts on the roof that I had to remove and welded the holes up. Both top corners were caved in as well.
I also finally got around to getting the cantilevered rear shocks designed and built.
Here's a quick video of it in action...I don't know why it made a little pic for the post...just click on it.
Instagram: lofab77
Old 04-01-2016, 02:23 AM   #244
ruffrida2005
That came out pretty damn good.
Paul
Old 04-01-2016, 01:23 PM   #245
RNmatt87
Looking really great. Love the fab work on everything.
RNmatt87 is offline   Reply With Quote
Old 04-04-2016, 11:49 PM   #246
75Dually
75Dually's Avatar
I finally went through your whole build, wow man great build! You've come a long way since the start. I kept thinking "I've been there, and there, and there..." Really enjoyed going through that, keep up the good work!!! BTW you need a watts link, ditch that panhard bar. You'll be glad you did.
Again great build, can't wait to see more!
75Dually is offline   Reply With Quote
Old 04-04-2016, 11:53 PM   #247
75Dually
75Dually's Avatar
In case you have not seen it here is my York build page. Check it out it might give you a couple of ideas. Your going to want one of these long term. To fill my 8 gallon dual tanks up to 200 PSI takes just about 45 seconds from empty to full. Had some friends with dual electric pumps in my truck at LST and they were blown away at how fast it took to fill. If you have any questions just let me know.
http://www.duallyscene.com/threads/15485
Old 04-09-2016, 07:25 PM   #248
DblTrbl
DblTrbl's Avatar
Thanks 75 Dually. I may end up swapping to a watts, but I'm really limited on space between the pumpkin and gas tank. Might be another project for next winter. I plan to go dig through the junkyard soon and look for a York. The 480's are really taxing my battery...
Instagram: lofab77
Old 04-09-2016, 07:30 PM   #249
DblTrbl
DblTrbl's Avatar
I finally finished up the bodywork and got some color laid down late yesterday afternoon. Ran back and forth to the paint store several times to get the color dialed in and the right amount of metallic with the flat. It's darker than I'd expected, but it's growing on me. I'm mostly just glad to see it all one color now...
Instagram: lofab77
Old 04-09-2016, 08:33 PM   #250
daddyjeep
daddyjeep's Avatar
Looks much better now.
04 1500 crew cab
