#1001 |
Re: 1949 Chevy 3600 into a daily driver
that may work too, just have to make sure the Aarm isn't going to hit it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#1002 | |
Since I want a daily driver when finished, I am reconsidering these as a choice. Just my 0.02 worth. |
#1003 |
I have about 1k miles on mine and smooth as can be. You should grease them every few thousand miles. tons of s10 guys run them. They are a needle bearing design, nothing different from a wheel bearing really. If you have the money to spend 3-4's time as much right off the gate, I'd say yah go that route, get some poly bushed uppers.
#1004 |
Super busy day.
We now have a roller. Such a great feeling. My Knuckles showed up from IRS Machining today. They look great!! That allowed me to assemble the rear suspension. ![]() I am about 1/2" to 3/4" higher in the rear than during mockup, which I found out to be the difference in the stock T-bird wheels and my Cragars and WW. Looks like I could easily take 3/4" out of my lower cups to get lower. Now sure if I will or not. The only part that really bothers me is the running boards are not parallel with the ground at air out. Kind of a pet peeve of mine. The back either needs to come down, or I need a bumpstop to raise the front 1/2" at air out. The front is all loose mocked up. Just enough to roll. ![]() ![]() |
#1005 |
Nice, such a good feeling to get it rolling. I agree with the running board almost level aired out, never looks intentional.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1006 |
Just went through your build, very cool.
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#1007 |
Looking Good!
#1008 |
Oh my gosh....you are doing a great job on this truck...
Congrats on getting it rolling... MikeC |
#1009 |
Thanks guys!!
Pulled him out of the garage and am cleaning the shop now......... |
#1010 |
![]() Join Date: Mar 2007
Looking good.....Its always nice to get it back to roller status.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#1011 |
Happy to get him rolled out of the garage and get it all cleaned up.
![]() I spun spun him around and put the 350/350 combo in to the rack and pinion mocked up. ![]() ![]() |
#1012 |
Still plugging away on this install.
Threw the motor in to mock up the rack and pinion set up. ![]() The mounting on this rack was offset to the drivers side which makes mounting a bit more troublesome. I picked up some 4" x 4" x 3/16" tubing to make some mounts out of. Scott suggests a 3" notch to clear the rack. This WILL NOT work with a Ford rack. I had to open up my notch to almost 6" to clear the Ford rack. Frustrating to cut apart something that was finished. ![]() I had to remove some material on the passenger side of the crossmember to clear the rack. I got a little overzealous with the skinny wheel and sawzall. ![]() mock up ![]() ![]() Making brackets ![]() ![]() Tacked in ![]() Fit test. I did end up opening up the notch after this. ![]() Both side welded in and the relief boxed in. I just need to rebox the bottom of the notch!! ![]() |
#1013 |
great job, I feel yah on cutting up finished stuff. but that's the name of the game. you handled it well.
#1014 |
Thanks!!
#1015 |
Still pluggin away. Motor is now buttoned up. New set of reworked 601 heads installed.
![]() I threw a fresh coat of Chevy Orange on the motor and tossed it back in the chassis. First thing on the agenda is steering. ![]() ![]() ![]() |
#1016 |
coming along. steering is always a treat on these.
#1017 |
![]() Join Date: Jul 2012
Saw on FB you sorted it out. Nice job.
#1018 |
Nice work....Getting closer to hitting the road.
Marc
#1019 |
![]() Join Date: May 2007
what a great look your truck has!
#1020 |
Busy weekend with family and kid obligations, but I did manage a couple hours in the garage.
I was pretty nervous about the steering set up before I even started. The input shaft of the rack was aimed right at my drivers side motor mount. ![]() The headers I am running gave me a couple good sized openings to get through. ![]() When it was all said and done it was not as big of a deal as I had dreaded in the first place. I modified the motor mount a bit so the bolt hole was closer to the block. This required extending the mount a couple inches and cutting the biscuit. Once I did this it allowed the clearance I needed. ![]() ![]() ![]() I mocked it up with a piece of dowl rod and it works great. Now I am going to pull the motor and weld up the modified motor mount and paint the area. Once that is done hopefully the motor will go in to stay. New parts are arriving daily. New rear calipers for the Ford 8.8. ![]() CPP Firewall mounted Brake Booster. ![]() |
#1021 |
#1022 |
I had a goal of driver by Memorial Day weekend, but I am not sure how realistic that is.
Plugging away as time allows. |
#1023 |
#1024 |
Below is a great thread on the HAMB about grinding your stock steering shaft to a DD.
http://www.jalopyjournal.com/forum/t...-tools.798515/ |
#1025 |
The pic from the front with it aired out looks so good. Steering check, nice new brake parts check.
