03-04-2004, 11:18 PM | #1 |
Iamnotanofficerofthelaw
How similar is the '88+ to the '73+? Trying to fit a big tire...
Hey guys, I was wondering if the '88-'98 rear half of the frame and suspension was at all close to the '73-'87.
I've seen plenty of bedless or frame off 73 and up trucks. And they look nearly exactly the same as the '88-'98. I'm talking 2wd trucks. How close are they alike, if not exactly? How about the the rear end width, is that the same? Only reason I ask, is I want to run a wider wheel/tire in the back. I want to keep it inside the fender like it would be from the factory without rubbing the leaf springs. I was thinking 295 or 305 on a 10" rim if that would fit. How wide of a wheel/tire are you guys running without problems?
~Paul~ '96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock '87 S-10 Ext Cab- 2.8L/700r4 KIA Caught fire 12/7/03 |
03-05-2004, 12:15 AM | #2 |
32x11.50x15 on an 8" rim..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
03-05-2004, 12:49 AM | #3 |
Actually, today, I seen a 73-87 C10, with a 88-98 bed on it. Looked strange, but not too bad...
BTW: Jon is running my old set of 32x11½ 15's, and I had them on my 2wd (as he does.) I THINK on a 4wd, you can run 33's. |
03-05-2004, 12:58 AM | #4 |
i think he is wanting width more than height.
03-05-2004, 12:59 AM | #5 |
Anything you can run on a 10" rim will probably work fine, you would have to have some REALLY wide wheels with tons of back-spacing in order to rub on the rear springs. I have 12.5" wide tires on 15x8s and there is PLENTY of clearance.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
03-05-2004, 01:37 AM | #6 |
I just want to run a wider rim and tire without having it stick out of the fender and also not rub the springs. Still trying to keep it looking 2wd.
03-05-2004, 01:42 AM | #7 | |
03-05-2004, 07:21 AM | #8 | |
Exactly.
