Old 03-10-2016, 08:02 PM   #1
blown240
blown240's Avatar
I Hate Asking Stupid Questions......But
I hate to ask stupid questions, but I've searched and can't find the answer.
I put power steering in my 61. The new pitman arm doesn't have a hole for the cotter pin, so I want to put a nylock on it, as I found when I searched.
The problem is that I don't know what size it is. I read 7/8-14, but thats HUGE compared to this.
Does anyone know the size of this nut, or should I just put some red or blue loctite and torque down the castle nut?
Thanks!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 03-10-2016, 08:08 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: I Hate Asking Stupid Questions......But
Do you mean the shaft on the steering gear box?
Old 03-10-2016, 08:10 PM   #3
blown240
blown240's Avatar
I mean pitman arm to center link.
Old 03-10-2016, 08:25 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
It should have had a hole in it. The one on the box does not.
Things that make you go... hmmmm...
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-10-2016, 08:27 PM   #5
blown240
blown240's Avatar
Ya I was surprised it didn't have a hole. It's off of an 81 c30.
Old 03-10-2016, 09:33 PM   #6
61ChevyPanel
Active Member
61ChevyPanel's Avatar
I sold fasteners for years. The size of the wrench used on a fastener isn't measured since there are many head types. A 1/2" bolt will measure 1/2" in diameter. Measure the diameter of the pitman arm threads, an end wrench works well. If it measures 7/8", then it's a 7/8" nut. The hole in a 7/8" nut won't be 7/8", it will be smaller.
Once you determine the diameter of a bolt or nut, you must determine the number of threads per inch. Non-metric fasteners are most commonly either coarse thread or fine thread but there is extra fine thread such as what's used on carb linkages. A 7/8" coarse thread has 9 threads per inch and a fine thread has 14 threads per inch. Thread charts can be found online. You could use a thread gauge, or count the threads per inch or if you have any spare 7/16" bolts, a 7/16" coarse thread bolt has 14 threads per inch. A 7/16" - 14 bolt coarse threads will line up perfectly with a 7/8" fine thread because they both have 14 threads per inch.
Bolts are specified by the diameter, threads per inch, then length. The length is measured under the head, except for flat head screws which are measured in overall length. For example a 3/8" - 16 x 1" is 3/8" in diameter with 16 threads per inch and one inch long under the head.
61ChevyPanel is offline   Reply With Quote
Old 03-10-2016, 09:56 PM   #7
Big Fenders
I think pitman arms are hardened so drilling for a pin would be difficult..If you can find a nylock nut that size it's what I'd do and check every so often.
No questions are stupid
Big Fenders is offline   Reply With Quote
Old 03-10-2016, 10:55 PM   #8
blown240
blown240's Avatar
Thanks for the replies guys!
61ChevyPanel - What your saying makes sense, so I went out and checked the threads with a wrench. 9/16 won't go over them, and 5/8 has play. That makes me lean towards 16mm, but I know that can't be the case, because its the same size that the 61 had originally.
Ill go to a good fastener store and look at 9/16 and 5/8 fine thread. Ill take the castle nut I have and try to find a nylock.
Old 03-11-2016, 01:06 AM   #9
61ChevyPanel
Active Member
A 5/8" wrench will have a little play on the threads of a 5/8" bolt. On a bolt that doesn't have threads all the way up, the unthreaded part will be 5/8" but the diameter where the threads are is a little smaller. A 9/16" - 18 nut usually takes a 7/8" wrench. A 5/8" - 18 nut usually takes a 15/16" wrench but there are exceptions...
Old 03-11-2016, 01:38 AM   #10
blown240
blown240's Avatar
Great! It takes a 15/16 wrench I believe. I'll try to get to the hardware store tomorrow! Thanks!
Old 03-11-2016, 01:29 PM   #11
frankslagoon
I just put a gear box from a 82 on my trk. the new steering gears don't have a cotter key. The nut is a jam nut. as soon as ya start it on the pittman arm it will get hard to turn and continue to show resistains till it comes up tight. If you have the nut that came with the gear you will be fine. If it's good enough for GM it's good enough.
frankslagoon is offline   Reply With Quote
Old 03-11-2016, 01:44 PM   #12
blown240
blown240's Avatar
Thanks Frank.
Unfortunately I don't have the nut that came with it.
Old 03-11-2016, 02:27 PM   #13
61K10
61K10's Avatar
go to ACE hardware, they have lock nuts similar to a nylock.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-11-2016, 07:00 PM   #14
frankslagoon
Thanks Frank.
Well that's what I figured. to bad. might be worth goingto GM and buyin one. or try and get one at the wreckin yard.
Old 03-11-2016, 08:10 PM   #15
padresag
get a new one. they are only meant for one application
ron
padresag is offline   Reply With Quote
