Old 03-11-2016, 02:12 PM   #1
Born Lucky
custom trailing arms
I am making my own trailing arms. I have searched the vendors of this products and have from some nice ones but I have the resources so I decided to fab my own.
Would like some input on the design.
trailing arms.pdf
I plan on adding welding it up and adding holes and coil springs mounts.
Born Lucky is offline   Reply With Quote
Old 03-11-2016, 07:47 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: custom trailing arms
Hey Lucky, I've actually been planning to make some of my own as well. (I was considering a more tubular design).
Your drawing seems like a straightforward enough idea. Its almost like boxing the stock arms...but leaving the stockers out...if that makes any sense. I didn't see the provision for the bushing end for the trailing arm xmember. Are you going to build in a larger factory style bushing so you can keep the same xmember mounts...or are you going to go with a spherical bushing joint and switch the bracket as well?
I've been wanting to do the xmember and arms, going to a more tubular setup with the spherical ends and adjustable brackets. I think the downside of that is probably cost, and the slightly harsher/noisier life of those rod end joints (squeak squeak).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-11-2016, 07:55 PM   #3
Longhornss
make sure you use a spherical joint on the end of that arm.... see robnolimit's recent post on his trailing arm setup. a typical busing in in that arm will yield a harsher rige do to the lack of flex in the arm.
Longhornss is offline   Reply With Quote
Old 03-11-2016, 09:00 PM   #4
Born Lucky
YES i am going with Ballistic Joints, adjustable.
I am going 5 lug from 8 lug. I recently sold the Eaton HO52 and it left me with some sad trailing arms. So , I said-- I work at facility that has a fiber optic laser and the operator is my buddy. I am a welder there and have Draftsite program at home. So you can say I have the resources.
I just wanted some cool cut ovals and some other touches on the trailing arms.
So much inspiration out there with Delmo, No Limit, PORTERBUILT and us garage junkies.
Old 03-11-2016, 10:32 PM   #5
Longhornss
Old 03-11-2016, 10:35 PM   #6
Longhornss
I was going to use the ballistic joints when I was working on a 35 chev master project I have. Never finished that project but the joints were quality.
Old 03-12-2016, 10:01 PM   #7
racecougar
racecougar's Avatar
I did something similar to the design in your PDF.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 03-13-2016, 04:07 PM   #8
Born Lucky
How did you fab yours up? What gauge metal? There are nice.
Old 03-13-2016, 10:11 PM   #9
racecougar
racecougar's Avatar
Thanks. I don't recall what gauge steel we used, but the process was documented in my build thread (see sig) starting on page 11.
Old 03-17-2016, 11:11 AM   #10
bsampson
I was looking at fabricating a set myself after finding this post by nuke1 using 2"x3" rectangular tubing (3/16" thick):
http://67-72chevytrucks.com/vboard/s...d.php?t=387475
Before I bought the steel though, I came across a some good rust free 3/4 ton trailing arms for sale, so I went that direction.
bsampson is offline   Reply With Quote
Old 03-26-2016, 05:35 PM   #11
casey g
casey g's Avatar
Your design looks looks similar to my drop trailing arms I made.
casey g is offline   Reply With Quote
Old 03-26-2016, 05:35 PM   #12
casey g
casey g's Avatar
One more pic
Old 03-27-2016, 05:38 PM   #13
bmfpeterson
bmfpeterson's Avatar
those "drop" arms are sweet.....I went simple
bmfpeterson is offline   Reply With Quote
Old 03-29-2016, 07:34 PM   #14
Born Lucky
Originally Posted by casey g View Post
One more pic
Yup... very close indeed.
Nice...Some questions
Metal gauge?
What type of joint(bushing)?
Can you post photos of install?
Old 03-29-2016, 11:05 PM   #15
casey g
casey g's Avatar
3/16 if I remember correctly.
used ballistic fabrication joints
Old 03-29-2016, 11:08 PM   #16
casey g
casey g's Avatar
two pics installed. e brake cable mount wasn't on in the first pic.
Old 03-30-2016, 02:06 PM   #17
Born Lucky
That is one nice stance! Your fabrication was well done. I like your spring pad mounting area. I am looking into that for my set up ( your idea) but I am thinking to make it able to fit air bags in the future.
Old 03-30-2016, 02:16 PM   #18
Born Lucky
Can you school me on your drop arms?
I assume it is for more drop ?
