03-12-2016, 06:44 PM | #51 |
Re: Big Parts,4x4 stuff, Possible delivery MN, IA, NE, KS, OK, NM, CO, NW TX
Look'n for some clean 1972 1/2 ton axles and 71/72 GMC grill stuff.
03-13-2016, 04:26 PM | #52 | |
Vintage 4x4s
I've got a couple sets, let me get a couple pics.
Sorry no spare 4x4 frames at this time. I may part out a 72 c10 if it doesn't sell this spring. Or did you want 4x4 stuff? I've got a dana 44 front axle from a 71 to 79 truck (would need to run the numbers on it.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
03-13-2016, 04:34 PM | #53 |
thanx!
06-02-2016, 06:11 AM | #54 |
i need one of these bump stops, your best.
06-02-2016, 10:41 AM | #55 |
would you be willing to pull a nice soft ray rear window and the trim???
IT IS WHAT IT IS |
06-02-2016, 12:12 PM | #56 |
Hi Vintage Windmills, how much for the pilot eyebrow?
GMC Custom Camper 1972 |
06-04-2016, 10:17 PM | #57 |
Do you happen to have a set of front leaf spring mounts from a K20? If so, how much?
06-06-2016, 11:08 AM | #58 |
I am looking for a shift knob for a T221 transfer case for my 68 K10 and a gas pedal if you have it (67-70 style floor mount style).
Thanks, Jeff |
06-06-2016, 03:20 PM | #59 | ||
Vintage 4x4s
Everyone this is an old thread but I'm planning another trip to the same areas in September. look for a new thread in a month or two.
Not sure what part you are needing? Quote:
06-06-2016, 03:23 PM | #60 |
Vintage 4x4s
Paul, unfortunately that frame sold a long time ago, I wonder if other trucks used them as well.... let me look
06-07-2016, 01:13 PM | #61 |
Yes, just the pedal. Doesn't have to be perfect but functional.
Thanks - Jeff |
06-07-2016, 02:53 PM | #62 |
Thanks, please keep me in mind if you do.
06-18-2016, 10:34 PM | #63 |
i need that clutch rod, still have it?
10-09-2016, 04:41 PM | #64 |
Any front brake hardware 3/4ton drum? 12". Need adj wheel spring
05-17-2018, 05:29 AM | #65 |
By chance do you have left front out shaft for a Dana 44 or gm 10 bolt
05-17-2018, 11:38 AM | #66 |
PMd you.
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 |
