Old 03-13-2016, 01:27 AM   #1
burban nate
Crew cab cab & chassis frame vs pickup frame
I haven't looked at one but are the crew cab long box frames and the crew cab cab and chassis frames the same? '81-'91
Thanks, Nate
Current Project: 1990 V3500 CC dually.
burban nate is offline   Reply With Quote
Old 03-13-2016, 04:00 AM   #2
andrewmp6
Re: Crew cab cab & chassis frame vs pickup frame
No the cab and chassis is straight on the back half where a pickups has a curve in it,Then you have the wheel base which the cab and chassis is a longer wheel base then any truck.
Old 03-13-2016, 08:25 AM   #3
GM72K10
Next!
GM72K10's Avatar
I think he's asking about a Crew cab C&C which would have the same wheelbase as a Crew Cab pickup. Model 30943, 164.5"
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 03-13-2016, 10:33 AM   #4
80SPORT
80SPORT's Avatar
The crewcab cab and chassis frame and 30 series crewcab pickup frame are the same;both are 56 inch cab/axle.This was always a problem for tow trucks and custom bodies as the reg cab dimension for cab/chassis was 60 inches.To convert a cab/chassis to dually pickup in a crewcab you just need the wide track rear axle.
80SPORT is offline   Reply With Quote
