Old 03-16-2016, 10:25 AM   #26
84blaze
Re: 1959 GMC 9310 Canadian built Shortbox Fleetside Deluxe
Originally Posted by Foot Stomper View Post
Do you mean this one???
That truck was built by Sam at Epic Rod and Custom in Calgary, AB. He does awesome work.
84blaze is offline   Reply With Quote
Old 03-16-2016, 10:37 AM   #27
dsraven
are you sending the cab for blasting or just some other smaller stuff? just curious because that is when you really find out what you have. make sure to really check your cab mounts and door hinge pillars. maybe even do some measurements while there is still something left to measure. pics say a thousand words later when you are looking at the empty spot and wondering what it looked like before, haha. trust me. I only had 1/2 a truck left after blasting mine. lots of guesswork when it comes time to weld in the new panels.
curious to know where you will go for blast work. do it yourself or have it done? a buddy of mine sent stuff to a guy near Conrich(?) somewhere. let me know if you need his contact info, just pm me. buddy was happy with the work I think. the guy does it all the time so gotta know what he is doing. I did mine myself just because that is how I roll. what a mess though.
Old 03-16-2016, 10:39 AM   #28
dsraven
here is a snap of some of my parts after blasting. lots of sharp edges.
Old 03-16-2016, 11:04 AM   #29
Foot Stomper
Foot Stomper's Avatar
Great suggestion about taking some measurements!
The blaster is in Regina, Sask...not far from where the truck is currently in surgery. Ken has had blast work done there before so trusts that the truck will come back as straight as it was delivered....minus the cancer.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 05-18-2016, 10:52 PM   #30
Valarius_Starchaser
Valarius_Starchaser's Avatar
Wow now thats a thorough blast session I'm in for the build!
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 08-24-2016, 06:43 PM   #31
Foot Stomper
Sorry for the lengthy and delayed update.
Summer does bring distractions but it also brings opportunity. I found this started and abandoned 1955 project so I scooped it up as it saves many dollars and much time. It's a 1955 GMC shortbox step side that's been rebuilt from ground up. New engine and springs and shocks and brake lines and and and! The cab is not paint ready but has been blasted and all sheet metal work is done. Frankly, I could not resist it...it was such a good deal.
Old 12-12-2016, 08:08 PM   #32
Foot Stomper
So the donor is in the shop and replacement fenders getting the treatment.
Old 02-05-2017, 11:43 AM   #33
Foot Stomper
Media blasting and epoxy primer done on front clip and cab. Notice the lead work that a master craftsman did in years past?
Old 02-13-2017, 02:23 PM   #34
Foot Stomper
More priming done!
Old 02-13-2017, 02:28 PM   #35
Foot Stomper
Lower hinge cage nuts installed and a bit of stitching on the cab corners was in order.
Old 02-13-2017, 04:24 PM   #36
CMACDONALD1
CMACDONALD1's Avatar
Great progress! Looks awesome.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts.
1972 Cheyenne Short Bed
1958 Apache short fleet
1980 Chevy short bed
http://67-72chevytrucks.com/vboard/s...d.php?t=761005
1959 "Henry"
http://67-72chevytrucks.com/vboard/s...d.php?t=670461
1966 Biscayne
http://67-72chevytrucks.com/vboard/s...d.php?t=444419
1972 Suburban
http://67-72chevytrucks.com/vboard/s...d.php?t=478828
CMACDONALD1 is offline   Reply With Quote
Old 02-13-2017, 04:55 PM   #37
dsraven
I am sure you are on it, but don't forget to leave a drain at the bottom of the pillar and also a bracket for the lower fender attachment bolt.
you are sooooo far ahead of my project.
lemme know if you need to take a look at the frame I have to measure for rad support brackets.I am back from holiday now, so just work to interfere with projects, haha.
looks good. and 2 cabs at the same time in the shop.
Old 02-13-2017, 05:32 PM   #38
RockinKees
RockinKees's Avatar
Looks great!!
I too made a drain in the a-pillar, after I saw a 1/2" water in it....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-13-2017, 06:00 PM   #39
II_Slow
II_Slow's Avatar
I AM SO GLAD I am past the rust repairs on mine. Yours sure looks great in primer. Keep it up!
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 02-13-2017, 06:51 PM   #40
Foot Stomper
Thanks for the advice and compliments guys!
A drain hole was not in our plans but certainly makes sense now that you've brought it to my attention.
The brackets for the lower fender mounts are ordered and in their way. I realize a tab could be made but thought I'd splurge.
I just want to mention that all of the hard work is being done by my high school buddy Ken, and deserves all the credit. Any parts or pieces I can buy to save him time I gladly buy!
I visited him recently and spent a couple days dragging parts back and forth to the media blaster. Then we got to hanging parts for primer, blew them off, wiped them down with wax and grease remover to be safe. I sprayed a fair bit of the primer but got out of his way as he was far better and faster than I was.
Old 02-13-2017, 08:39 PM   #41
Kim57
Kim57's Avatar
Coming along nicely.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-13-2017, 09:45 PM   #42
dsraven
have you tried keystone parts in calgary for tidbits? I have bought a few items there. door hinges etc. they have an online catalogue that you can log in under a visitor. at least you can see what they have access to.
Old 02-20-2017, 05:42 PM   #43
Foot Stomper
Took some Autosol to the grill and number badge and decided to get them rechromed. Pitting just isn't going to get a "pass".
BTW, in Canada 9310 is the model of the US 100 equivalent.
Old 02-20-2017, 05:45 PM   #44
Foot Stomper
Received my bed strip bolt down kit, tailgate latches and one of my cab to fender brackets this week.
Old 02-21-2017, 04:25 AM   #45
Nut Case
Nut Case's Avatar
Foot Stomper
This a good start, progress looks great. When I get going on my 57 Jimmy, I need to replace the bottoms of the drivers side and passengers sides corners.
My plan is to replace the bottom metal with a metal peace that has 1/2 holes in a decent pattern, and then have a 10 degree slope from front to lower in the back, you know going towards the back of the truck. Leave a rectangular opening about a 1/2 high, that way the big sludge has an exit as well as a slope to help clogs on there way right out.
Think about it, I will on my project when I can get it off perma-hold which is looking better all the time.
Keep on keepin on
NUT CASE
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 02-28-2017, 12:53 PM   #46
Foot Stomper
Thanks Nut Case for the advice. Cab corners won't get drain holes on mine because the interior shouldn't see any water (unless I am misunderstanding you). The A pillars are scheduled for drain holes...after the lower cab to fender mounts are welded in place.
Spent some time this past weekend polishing some hub caps. I purchased 4 new Chinese knock offs, but I need a fifth one for the spare that'll be mounted in the box. I purchased these originals awhile back and found that I have one really good one out of the set so it's polished up now and only needs the center to be painted red. Does anyone know the correct red? Is it Flame Red from the 1959 GMC truck color card?
Anyway, here are some pictures of caps before and after. I used Autosol metal polish and a microfibre cloth and my wife's toothbrush for tight areas. It took about 10 minutes to clean each hub cap.
The dented hub cap is showing before and after the polish. It will become wall art...
Old 03-01-2017, 07:22 AM   #47
RockinKees
RockinKees's Avatar
That cleans up nice!!
Hope your wife has a new toothbrush??
Cheers!! Kees.
Kool Guyz CC
Old 03-01-2017, 08:47 AM   #48
Kim57
Kim57's Avatar
Came out real nice.
Kim
My build thread
Old 04-15-2017, 06:04 PM   #49
Foot Stomper
Well I decided to get the hood emblem and the 9310 emblem replated. Looks pretty nice now!
The passenger door is rust free now and all repaired ready for high build primer so it's getting fitted first.
Old 04-16-2017, 12:15 AM   #50
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
