Old 03-05-2004, 01:32 PM   #1
danho
Pesemistic Optimist
danho's Avatar
Steering Wheel
Are these wheels a total direct bolt on, or do you need adapters for anything like the horn, etc.?
Thanks, Dan.
danho is offline   Reply With Quote
Old 03-05-2004, 02:01 PM   #2
griesel72
griesel72's Avatar
They bolt right on, but i didn't have the horn mech, so i had to do a little modification
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 03-05-2004, 03:16 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have a thraed in the FAQ showing how I have done it on all of my trucks.
Old 03-05-2004, 03:16 PM   #4
flip66
flip66's Avatar
If I rember right the horn contact is diffrent but you should be able to get the right one at any auto parts store in the help Items. I know Auto zone has them.
flip66 is offline   Reply With Quote
Old 03-06-2004, 02:46 AM   #5
1972C10
1972C10's Avatar
You just need to run a wire from your turn signal cancelling cam to the horn button . No big deal i soldered a wire to my horn contact not for a wheel like that but i have had one of them on a truck in the past just too big for me so i got a grant GT .
If you take the stock turn signal cancelling cam out you can jab a wire into the area where the original contact is then get it to come out the back side wich is away from the acutaly contact area and solder it to a little brass tab .. Kinda hard to explain If i have an extra one around ill snap a pic of it.
1972C10 is offline   Reply With Quote
Old 03-06-2004, 05:29 AM   #6
Cruiser71
AKA Phillip Johnson, AKA BANNED
Is that out of an Astro van? Nice looking wheel.
Cruiser71 is offline   Reply With Quote
Old 03-06-2004, 03:28 PM   #7
67shortie
Green club
67shortie's Avatar
I have one of those wheels in mine, a direct bolt in. I don't have the horn hooked up yet though
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-06-2004, 06:17 PM   #8
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Horn hook up
Here you go. Use your stock horn contact. It works better than the late models.
Pull the pin out.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 03-06-2004, 06:18 PM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Cut a "J" shaped groove using Dremel or drill.
Phone: 360-956-7170
Old 03-06-2004, 06:19 PM   #10
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The late model wire has a raised tip.
Phone: 360-956-7170
Old 03-06-2004, 06:23 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The tip threads right into the "J" groove, like the late models. It is spring loaded, so that makes contact with your stock piece...and the other end of the wire has a spade that plugs into the late model horn button. No pics of that end. It is too simple to show.
WahLah! You're welcome! That will be $100, please
Phone: 360-956-7170
Old 03-07-2004, 02:43 AM   #12
Longhorn Man
That's pretty much how I did mine, but instead of cutting the J in the slip ring, i just shaved the nipples off the sring loaded contact piece and shoved it into the tube on the slip ring. It stays in there no problem and works great.
Old 03-07-2004, 02:46 AM   #13
71swb4x4
71swb4x4's Avatar
Longhorn man, is there a way to add the J-groove idea to your FAQ post?
I am not saying your idea isn't good enough, but it is nice to have the different ideas all in the same post for reference.
Can you just cut and paste PICKMUP's reply to it?
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-07-2004, 02:58 AM   #14
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Instead of cutting a "J" groove, Just use a female Bullet connector and slide it over the contact!!! Simple it doesn't take five min. to do. Also if you have a van tilt column you will have to file the aluminum inside the wheel to get it to go down on the shaft all the way.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-07-2004, 12:38 PM   #15
danho
Pesemistic Optimist
danho's Avatar
You guys never cease to amaze me, the good info just keeps on comin.
Dan.
1972 K20 Cheyenne Super Custom Camper- 4" lift & 35's, built TH350 and 355. Daily driver resto in progress.
1999 Yukon Denali- Wife's ride, hands off.
Old 10-11-2004, 10:13 PM   #16
Jimbotronics
YA YA
Jimbotronics's Avatar
I'm in the same predictament fellas - I installed the same steering wheel. With the stock slip ring installed I can get the steering wheel seated far enough down to get the bolt started. Any ideas? I also need that little wire if anyone happens to have an extra. Thanks, Jim.
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 10-11-2004, 10:21 PM   #17
Longhorn Man
Originally Posted by BLACK AND BLUE 67-72
...if you have a van tilt column you will have to file the aluminum inside the wheel to get it to go down on the shaft all the way.
Interesting, both my trucks have van tilts, and steering wheels like in the photo above, never had to file anything down...same when i installed one on a stock non tilt truck column, a simple bolt on.
Old 10-11-2004, 10:24 PM   #18
71swb4x4
71swb4x4's Avatar
Andy, you are replying to his post 7 months later
Old 10-11-2004, 10:28 PM   #19
Longhorn Man
JIM STARTED IT!!!!!
Old 10-11-2004, 10:29 PM   #20
Jimbotronics
YA YA
Is it possible that installation could be different pending on what the wheel came out of (i.e astro van, c1500, or S10). I have no idea what this one came out of. I'll take it back off tomorrow and give it a second look.
Jimbo
'04 Chevy Avalanche
Old 10-11-2004, 10:31 PM   #21
Jimbotronics
YA YA
LOL - hey, I used the search trying to find more info - love that search tool!
Jimbo
'04 Chevy Avalanche
Old 10-11-2004, 10:38 PM   #22
Longhorn Man
lol!
Actually, i think they are all the same in the hub and the wheel's frame. I think only the outer vinal skin is all that differs.
I can't see GM making one that is so clost to the other yet need a whole different assembly. Same on the columns too...they use the same part number in every aplication they can get away with.
Old 10-11-2004, 10:46 PM   #23
Jimbotronics
YA YA
lol - I would think so, hopefully I just wasn't getting it seated correctly.
A one bud-light job has turned into a six pack!
Jimbo
'04 Chevy Avalanche
Old 10-11-2004, 11:19 PM   #24
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
whats up with those steering wheels, everyone has one, and they are soo ugly, why does everyone buy one!??
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 10-12-2004, 12:02 AM   #25
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
because not everyone has the same opinion and they think they look good. i think the grant ones are ugly but alot of people like them. its just their 'bag'
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
