Old 03-18-2016, 04:43 PM   #1
Atbyrne
Atbyrne's Avatar
Th400 in a shortbed
Has anyone installed a th400 behind a v8 mounted in the rear holes on frame? If so does anyone have a length of the drive shaft? Truck was a 250 with 3 on the tree and 12 bolt rear end. Any information will help.
Thanks Travis
1966 Chevy C10 2WD SB
Atbyrne is offline   Reply With Quote
Old 03-19-2016, 12:12 AM   #2
Captainfab
60-66 Nut
Re: Th400 in a shortbed
You can not go by the length of driveshaft that someone else used. To be correct, you must measure what is needed for your truck, and then have the driveshaft shortened or built accordingly. Is your TH400 a short tail shaft or long? If short, does it have a bolt on yoke or is it a slip yoke?
Old 03-20-2016, 11:15 AM   #3
Atbyrne
Atbyrne's Avatar
Not sure on the tail shaft. I did measure, was just wanting to see what others had come up with. I already have shortened it and installed it. Thanks for the information.
