HD Chromoly Panhard Bars
The Gearbox Garage announces the introduction of their G-TR Precicion Components Heavy Duty Double-adjust Chromoly Panhard Bars for '65-72 GM Trucks with coil spring rear suspension with 0"-4" of drop. Introductory retail price is $119.99, forum members save 10%, making the price $107.99. Each kit comes complete with QA1 XM Series Rod Ends and all necessary Grade 8 Hardware to install and are Black Powdercoated.
Re: HD Chromoly Panhard Bars
a couple questions:
does this mount in the factory location? and is factory length (only adjustable) or is this a long bar with the additional brackets to mount from side to side? Any install pics? Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Dave,
Yes, this mounts in the factory location for "mild" drop applications of 4" or less. They adjust at both ends through RH and LH threaded Chromoly Rod Ends, so there is no need to remove one end to adjust the position of the rear-end. Just install each end, adjust to desired length, and tighten the jam nuts. I will post up some install pics this evening or early tomorrow. Thanks, Mike |
A short 'easily' adjustable PHB has been sorely missed in the market. Kudos for stepping up & filling the need.
#5 | |
Also really nice to see the hardware as a kit because it is very frustrating dealing with missing hardware and having to wait weeks/months for replacements. Nice job!
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
Thanks, guys! Yeah, we are trying to make our kits as complete as possible, this does increase the cost a little, but much better in the end for the customer.
P.S. We will be posting some install pics later today! |
Yes this is great news, thanks for the info.
Install pics on a '66 with 4" drop springs.....
Still have some of our HD Panhard Bars under the introductory pricing. Forum member price $107.99!
Are those panhard bars single or dual sided on the adjuster
Posted via Mobile Device |
Our Extended "Series 2" Panhard Bars are ready to release! They will offer the same quality TIG welded 1-1/4" Chrome-moly tubes and XM Series Rod Ends at both ends to simplify adjustability. All necessary Grade 8 hardware is included, as well as new U-bolts. The trailing arm mount provides 3 holes to adjust roll center, and also moving the mounting point back for a high clearance design when running large diff covers while maintaining a straight bar. Bars and mounting brackets come in Satin Black Powder Coat finish. Retail price is set at $189.99, with forum member discounts set at $15 off!
Christmas Special Get free shipping along with Forum member pricing of $107.99 on our Series 1 Chrome-moly Panhard Bars. They're fully TIG Welded with an integrated wrench hex on one end for easy tightening of the jam nuts and come Satin Black powder coated. XM Series Chrome-moly heim joints at both ends making adjustments quick and easy without having to unbolt them from the chassis. All Grade 8 mounting hardware is included. These are for stock to mild drops of 4" or less.
What is the range of length for the shorter bar (for the 6x-72 app)?
Do or can you make 'custom lengths'? What size are the retaining bolts? I have a custom app. I noticed this & remembered the OE 6x-72 bars are pretty close to what I need.
#15 |
anything for 73-87 trucks. like to have one for my 10 bolt. prefer a bolt on kit. something similar to ridetech bolt on one in their 4 link kit. but they don't sell it separately.
#16 |
SCOTI - The range is approximately 23-1/4" to 24-1/2" with 5/8" bolts to attach the heim joints to the frame. Currently, we are not producing custom lengths.
chevy-fun - Sorry, we don't have anything similar to that bracket at this time. |
#17 |
Prestige Worldwide
![]() Join Date: Feb 2001
Do you know if your extended bar will clear the PML Style covers that are deeper for more fluid?
Here is a link to the cover I am referring to: http://www.yourcovers.com/diffcover_6058.php Thanks, Jason |
#18 | |
I can't say for sure as I haven't used these specific covers. We created a mounting point on the trailing arm bracket that would clear T/A style covers, but I'm not sure how much of a dimensional difference there is between the two styles. I'm attaching another shot of our extended bar used in our coil-over set-up, which utilizes the same mounting point on the trailing arm. This angle may help visualize the clearance you are questioning. Sorry I cannot give you a definite answer on this one. Thanks, |
#19 |
Prestige Worldwide
Thanks for the picture....
I actually have a T/A style cover and one of the PM L's, I will dig them both out and measure them out and let you know. Jason |
#20 |
#21 |
![]() Join Date: Jan 2013
Are you still selling the panhard bars? That is one very good looking truck yall built.
#22 |
#23 |
Series 1, I only took it down 1 1/2 inches. Going to pick it up from paint in Georgia in a few weeks. I will be in touch to order it soon. Thanks
#24 |
