03-21-2016, 01:32 AM | #1 |
"The wifes truck" 1994 K1500
My wife still has her first truck and honesly dont even think she would sell it for anything. She bought the truck from a family friend on payments. Its a 94 K1500 with a 4.3 V6 and 4l60E. The truck as of now has 278,000 miles and we were using it as a back up vehicle till it blew a heater hose. The motor was tired, leaked oil so i didnt even waste any time fixing the 4.3. It prob sat for 8 months and is now in its current situation. I decieded to go ahead and do a 5.3 swap. I got a complete 5.3 from a junkyard and found a 4l60E and transfercase out of a 2002 truck. I plan to keep slowly fixing the truck up so figurd i should start a thread to show the progression.
As of today i have the engine and trans in. The only real clearence issues i have is the a/c compressor. Holley makes a relocating bracket that i will be using. I am using the stock harness that I cleaned up. I used most all info and had computer programmed by brendan at lt1swaps.com. I am using the factory cats and y pipe from the donor truck. This truck wiil have to pass the "sniffer" test for emmissions so I left the cats on.
52 Chevy 6400, 1 ton dually 4x4 350 vortec NV4500 315/75-16 tires http://67-72chevytrucks.com/vboard/s...d.php?t=661795 94 Chevy K1500 4.3 4l60e (The Wifes) |
03-21-2016, 01:35 AM | #2 |
Re: "The wifes truck" 1994 K1500
2000 truck 5.3 donor engine.
03-21-2016, 01:37 AM | #3 |
Tearing down to clean up and reseal.
03-21-2016, 01:39 AM | #4 |
Cleaned up
03-21-2016, 01:41 AM | #5 |
Old 4.3
03-21-2016, 01:43 AM | #6 |
Empty
03-21-2016, 01:45 AM | #7 |
Cleaning up the truck harness.
03-21-2016, 01:48 AM | #8 |
In the hole
03-21-2016, 01:52 AM | #9 |
Built a bracket to mount ECU in location of old air intake. I also moved the battery to the driver side and plan to run the factory air box fom the donor truck which will have to sit where battery is.
03-21-2016, 01:53 AM | #10 |
Mocking everything up.
03-21-2016, 01:55 AM | #11 |
Still need a/c bracket to verify clearence. Had to modify air intake also.
03-21-2016, 01:57 AM | #12 |
Mock up.
03-21-2016, 02:06 PM | #13 |
Here is a pic from a few years back when it was cleaned up. Sorry for the blurry pic.
03-21-2016, 05:10 PM | #14 |
looks like you'll have a great driver
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
03-22-2016, 06:51 AM | #15 |
Bout ready for another 270K-ish miles!
03-22-2016, 01:37 PM | #16 |
Holley relocating bracket and spacing kit. I got it installed last night. There is some clearnce issues if trying to use the stock intake piping fron filter box to intake manifold. There is a piece that hangs off the bottom. I cut it off and plugged the round hole. Also had to heat a small area on top with heat gun and push it down. The other alternitive is i know the spectre cold air kit off of a 2000 will work with no issues also. My buddies truck has one and i test fit it so it will also work. The low pressure line is a little to short, my solution is to cut the aluminum tube at compressor fitting and reweld for a better angle. I slso got the shift linkage hooked up last night. Had to modify it also for clearence because newer trans had the black box on side. Hopully tonight i will get the fuel lines connected and the intake bolted down for good.
03-22-2016, 01:40 PM | #17 |
Compressor installed. Belt length is around 108.5 inches. Will post part # when i find the best fit.
05-01-2016, 11:38 PM | #18 |
Its been a while since my last post. Truck is running and driving. Put a thrush muffler on it. Has a nice tone. Wife loves the sound. Still have a little wiring to finish up. I also changed the rear leaf springs from a light 3/4 ton, (6lug). May eventually put the 14 blot in it. The center caps were rusty. I came aross some stock center caps for free. Had to modify them on a belt sander to make them work but like the look. Today i swapped grill and put a less bent up bumper on it i had. Got a cheap ebay light kit. Looks good but lacks in quality.
05-01-2016, 11:40 PM | #19 |
Thrush muffler
05-01-2016, 11:43 PM | #20 |
Factory center caps with mickey thompson wheels
05-01-2016, 11:47 PM | #21 |
Before... Grille and bumper
05-01-2016, 11:48 PM | #22 |
After... Still need some cleaning on the grille and bumper but happy with the looks.
05-01-2016, 11:56 PM | #23 |
Oh yeah the leaf spring swap. I changed them for a couple reasons. The truck has a lean or sag to the left and she will be using to pull her small aluminum horse trailer. Well the leaf springs didnt fix the lean. Maybe a soft or weak tortion bar?
05-02-2016, 11:50 AM | #24 |
Have you read anything about using the TBI style AC bracket on the 5.3? I am going to look into this for mine since I am not going to notch the frame for it. I need to look into engine mounts too.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
05-02-2016, 12:34 PM | #25 |
Havent seen that one. I used the holley bracket. Little pricey but works great.
