Old 03-21-2016, 10:59 PM   #426
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Also finished the other side of the tailgate cable bolt hole by using a hole saw and welding a nut to the back of a washer the same size as the hole and welded it in Flush then Cleaned the welds off. And I did some bodywork on the modified fender but nothing post-worthy.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 03-21-2016, 11:50 PM   #427
1963chevy
take your tires off your wheels when you sand blast them. you can manipulate the wheel in a cabinet alot better then you can a wheel with the tire on plus you dont want to accidently hit your rubber then your sol on the tires. plus when you paint them it will make it that much easier to paint the whole wheel or powder coat or what have you. the truck looks awesome im tuned in!
1963chevy is offline   Reply With Quote
Old 03-22-2016, 12:20 AM   #428
62stepside longbox
Thanks, I didn't paint them before I mounted them because the machine at my school has scratched lots of rims and I didn't want that to happen to mine. And I don't have to worry about sandblasting as I decided to just sand them as it didn't actually take that long. When I paint them I'll just tape them up.
Old 03-22-2016, 10:32 AM   #429
60chevyjim
60chevyjim's Avatar
your fender looks great , I need to do my truck like that too .
I like the tailgate cables too . the drive shaft cut looks good .
60chevyjim is offline   Reply With Quote
Old 03-22-2016, 12:10 PM   #430
62stepside longbox
Thanks Jim, I plan on welding the yoke on today using the instructions you gave me, I'll check that its square many times then I'll put a couple tack welds and if it's still perfectly square I'll keep welding and checking.
Old 03-22-2016, 06:31 PM   #431
62stepside longbox
Welded my driveshaft up today. Checked over and over to make sure it was square and tack welded it, checked more and finished up the weld. I'll pick up a new ujoint and put the driveshaft in tomorrow or the next day. I think it'll work just fine.
Old 03-22-2016, 06:35 PM   #432
62stepside longbox
Also did some more work on the tailgate. I shortened the cables about 3". The bottom one hadn't been done when I took the pic
Old 03-22-2016, 06:39 PM   #433
62stepside longbox
Then I made some little brackets out of angle iron and drilled a hole in them and welded them to the gate. I then bolted the cables to the bracket with a bolt and two nuts and tightened them together so the cable can spin freely.
Old 03-22-2016, 06:40 PM   #434
62stepside longbox
Here's the gate down
Old 03-22-2016, 08:12 PM   #435
62stepside longbox
The chains have been retired of their duty
And here's a video of the gate cables. http://youtu.be/fMepTpBTR7w
Old 03-22-2016, 09:01 PM   #436
60chevyjim
60chevyjim's Avatar
keep up the good work !!
Old 03-22-2016, 09:31 PM   #437
62stepside longbox
Thanks Jim
I just went out and got a new u joint and installed it and put the driveshaft in, I should be on the road soon
Old 03-22-2016, 09:32 PM   #438
62stepside longbox
01
Old 03-22-2016, 09:33 PM   #439
62stepside longbox
02
Old 03-23-2016, 05:12 PM   #440
62stepside longbox
Tryed starting the old beast up today and it started easily enough but I didn't get to warm it up as it was leaking gas badly from the intake manifold. This made no sense to me as first because I put a new gasket in and made sure both surfaces were clean the tightened it up. When I took it all off I found that it was a problem with the new gasket. It wasn't the correct shape and the metal sleeves on the manifold were jamming on the gasket and not seating properly.
Is it normal to have this much carbon on a gasket with tops 15 minutes of running time on them (Most of that time was with the choke on)???
Old 03-23-2016, 07:21 PM   #441
62stepside longbox
Hi everyone here's an update on the 261. its Starting now but still not running right I just can't take the choke off even if it's warmed up and it's super loud. Here's a video to explain http://youtu.be/tsGegjKaos8 thanks
Old 03-23-2016, 07:22 PM   #442
65sub
65sub's Avatar
Looking good Nik. That carbon is likely from an exhaust leak
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 03-23-2016, 07:31 PM   #443
62chevy302
hillbilly
62chevy302's Avatar
Exhaust sounds like its leaking from the sound and if the intake is too that would explain the choke needing to be on. I would say you have a leaking intake and exhaust manifold gasket
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 03-23-2016, 08:23 PM   #444
My thoughts exactly, some sort of manifold or vacuum leak.
Old 03-23-2016, 09:16 PM   #445
62stepside longbox
Thanks Dale
Ok so it seems that it is the manifold gasket leaking but it is brand new and is not jamming or anything when being installed and the bolts are pretty tight. I cannot think of anything other than the two surfaces are not clean.(but I did sand and clean them) I'll pull it all of again tomorrow and see what's up
Old 03-23-2016, 10:46 PM   #446
TJ's Chevy
TJ's Chevy's Avatar
Time to check for manifold flange warpage and a new gasket. I remember changing it on mine and it ran real good afterward.
Old 03-23-2016, 11:25 PM   #447
62stepside longbox
Tj the gasket is brand new, it has maybe 10-15 mins of use on it. I will check for warpage tomorrow
Old 03-24-2016, 05:30 PM   #448
62stepside longbox
This motor is really starting to make me frustrated. I pulled the manifold again this morning. First I cleaned the surfaces off and made sure they were perfectly flat, then I trimmed the gasket so it fit perfectly and then cleaned it up and used some hight heat gasket maker to help seal everything. I then bolted it on carefully and torqued it to the correct specs and then waited so the gasket maker could dry. Then I fired it up and got the same result, bad vaccum leak and exhaust leak. Any suggestions on what to do now? Thanks
Old 03-24-2016, 06:14 PM   #449
My guess is that gasket is toast. It has been too long for me, but is that a factory gasket or an aftermarket one> I used a hi-performance gasket on my old 250 when I had to replace an exhaust manifold. It was thicker than factory and seemed tougher. Now whether I really needed it or not , I don't know. I just got one cause it looked better than the stock one. (from Summit Racing)
Old 03-29-2016, 11:25 PM   #450
62stepside longbox
Here's a bit of an update for everyone. Been doing lots of bodywork so nothing too picture worthy. Here's the fender with almost all the bodywork finished.
