twin turbo 540
Anyone got this setup in their truck ? or I going to be the First.
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
Re: twin turbo 540
Well I guess we are waiting for fat tires an big horse power pics.
Active Member
![]() Join Date: Aug 2012
Re: twin turbo 540
Like the title... details please
Re: twin turbo 540
Well, I was inquiring to see if anyone has done it yet or am I the first to do it.
So lets start with the truck . 1964 C10 short bed small window the one in my avatar. dropped 3inches in front 6 inches out back. coilover on rear 250lb spring adjustable shock. 9 inch that measures 52 inches hub to hub 18x29x15 tire street/13inch slick strip. Boxed frame and going to do some more chassis work. Front suspension is cpp tubular arms with sway bar. Custom disc brakes on all four corners . I will take pics as it comes together. Lets talk about the fun part, the engine. BBC 540 twin turbo. heads AFR 325 cnc intake edelbrock efi block Dart Big M with billet mains crank eagle 4.25 forge (what I had) rods eagle 6.385 H beam Arp 2000 bolts turbos are BW s480 80/93 1.32 ar cam is going to be custom grind and running crower shaft rockers
Re: twin turbo 540
Sounds sweet! Is it still trailing arms in the rear?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Re: twin turbo 540
yes it is will post pics soon
Boosted Member
Re: twin turbo 540
I've got a turbo setup in my truck...but only on 370 cubes.
I am planning to put together a similar TT 540 BBC setup in my Chevy II though.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Re: twin turbo 540
I have a really nice 548 I will sell you but you would just have to swap pistons to be boost friendly! I think I really want a bigger Motor.
Re: twin turbo 540
I got all the big parts already.
Re: twin turbo 540
Machinist
Re: twin turbo 540
This is my twin turbo build..... Im a little shy of the 540ci mark
#12 | |
Active Member
Re: twin turbo 540
Re: twin turbo 540
Ok got a little work done today. tore the 514 gear set out and put a 350 in running a Moser bolt through third member. working on a bigger fuel cell next. here are some pics . that's one of the turbos a teaser..lol
Re: twin turbo 540
got the tank almost done .got to finish tomorrow.
#15 |
Re: twin turbo 540
I would put a back brace on the 9 inch.
#16 |
Active Member
Re: twin turbo 540
Nice! What kind of fuel pump are you going to use? Rear end is 3.25 tube? Looks stout... nice setup!
#17 |
Re: twin turbo 540
yes 3.25 tubes dom running a external pump that's good for 1000 hp to start(its what I got) then upgrading to something that will handle 1500hp
#18 |
Re: twin turbo 540
At what HP Rating do you starting thinking about a back brace?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#19 |
Re: twin turbo 540
#20 |
Re: twin turbo 540
don't plan on back brace do to the DOM tubing and the narrow rear . also not using a trans brake .
#21 |
Re: twin turbo 540
started on the hot side of the turbo's t6 flange 4 into 1 2 inch sch 10 stainless
#22 |
Re: twin turbo 540
i'm subscribed doing this exact build right now in my 72 street truck.
Dart big m block 9.8 callies billet crank and billet rods diamond pistons dart pro 1 355 cc heads crane gold roller rockers custom grind cam jesle belt drive daily engineering drive sump set up twin bullseye 83 mm turbo's all arp bolts and studs holley dominator efi 16 moran billet atomizer injectors plazmaman billet intake edelbrok victor water pump coil on plug im running a fab 9 moser housing with back brace and 3.00 gears a rossler 4L80E stage 5 trying to figure out how to fit a water to air intercooler system with a killer chiller 20x14 budniks in the back with 29x15x20 mickey thompson tires sounds like we are both building something very similar |
#23 |
Re: twin turbo 540
Ok everyone making progress on the 64 I hope to have it running soon . so here are so pic to show what I've got done..
#24 |
Re: twin turbo 540
more pics... sorry I don't know how to rotate the pics. the engine in the truck is a mock up[ATTACH]
#25 |
Re: twin turbo 540
a couple more
| Bookmarks |
| Thread Tools | |
| Display Modes | |
