Old 03-23-2016, 10:10 PM   #26
Willowrun
Willowrun's Avatar
Re: the cheap build thread
Love the 6 cylinder!
Old 03-24-2016, 12:34 PM   #27
daddyjeep
daddyjeep's Avatar
Just curious...did you end up buying spring perches or just build your own? They are really easy to make out of some 1/4" wall 2 1/2" square tubing.
Truck looks good. I like the new stance.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-24-2016, 01:42 PM   #28
68Timber
I know the pieces fit
68Timber's Avatar
Nice stance and cool that you kept the 6-cylinder. The ones I've heard sound good with duals.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-24-2016, 05:13 PM   #29
Blessed66
Blessed66's Avatar
If I had a 250 or 292 laying around, I'd use it. They don't get the love they deserve, sometimes.
Cool build.
Current Projects:
1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion
1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently.
Blessed66 is offline   Reply With Quote
Old 03-24-2016, 05:38 PM   #30
cheap
I bought some spring perches, but now that you say that i could have just as easily made some up
Thanks for the compliments everyone! The exhaust does sound pretty good, but i'm running into a couple issues from leaks, i think i didn't fully weld a few joints. I'm pulling it off to inspect soon.
cheap is offline   Reply With Quote
Old 03-24-2016, 07:41 PM   #31
rusty76
rusty76's Avatar
Looking good
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-29-2016, 03:50 AM   #32
cheap
Long time no update!
I've been very busy with side work, but also kept up on this project. To recap, I had just finished up with a new inline 6. That went out the window, but first it got cut into a shorty.
This is freshly cut, all done with the ole reliable death wheel. I took roughly 14 inches out of the wheelbase here, and around 5 1/2 out of the rear,
The pieces took a little grinding to fit perfect, but it came out level and in a 1/16th of square.
I welded the joint on the outside, cleaned it up and fishplated the outside.
Finished product! not bad for what it is.
Old 12-29-2016, 03:55 AM   #33
cheap
The next step was the engine. The old sixer was cool but just didn't have all the power I was looking for. I picked up a pretty clean 350 locally for a deal, so I spiffed it up and put in a few speed parts I had.
Headers and an intake wake up a stock 350 pretty well
Old 12-29-2016, 04:00 AM   #34
cheap
Currently I'm prepping the truck for paint. I just started on the rockers an cab corners, and have the drivers mostly complete and the passenger just started. I've never done bodywork before, but it's interesting to learn and worth doing yourself even if it's not perfect.
Old 12-29-2016, 02:59 PM   #35
rusty76
rusty76's Avatar
Looks like you are making head way.
My build thread
Crossmembers CC
Old 12-29-2016, 03:41 PM   #36
palposity
palposity's Avatar
I appreciate a good budget build. Seems that you are coming along well. Keep it up!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 12-29-2016, 07:46 PM   #37
daddyjeep
daddyjeep's Avatar
For a guy that doesn't know what he is doing, you're doing a pretty good job on the rust repair. I'm liking the truck overall too. Keep it up.
04 1500 crew cab
Old 12-30-2016, 04:17 PM   #38
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: the cheap build thread
I agree with post of these guys!
im really digging this build i remember seeing your first post but i must have missed the updates
as said above keep it up dude
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 12-30-2016, 06:52 PM   #39
LT7A
This is cool. Following along.
Old 12-30-2016, 11:24 PM   #40
moregrip
moregrip's Avatar
nice build!!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 12-31-2016, 12:16 AM   #41
cheap
Thanks for all the support guys! This is the first time I've done bodywork, I've been trying to take my time and do it right. Better to do it right the first time, right?
This was one dent that actually pulled out pretty easy, the whole piece was able to just pop back out
This one was a little more complex. I first had to grind out about a half inch of filler, and was able to pull it mostly out, at least enough to be able to fill out with a little bit of filler.
Old 12-31-2016, 09:48 AM   #42
Omegadog
Omegadog's Avatar
Looking great so far. I'm doing a cheap mild just-the-bed-off resto myself. I can't afford much into my project because I won't pull monies from our household budget. LMC and O'Reillys are still getting a lot of my spare change these days. I've sold guitars and amps and traded a '96 GMC Jimmy etc. to get me to where I'm at now. My '84 Silverado shortbed is ready for body work now after I sorted out a ton of engine(305) work so I will be watching this thread closely.
BTW...PLEASE keep the rally rims and center caps.
Here's a before and after of the engine compartment...
Omegadog is offline   Reply With Quote
Old 12-31-2016, 05:26 PM   #43
cheap
Looks great! Mine's on a pretty tight budget as well. But the budget has definitely made me learn a lot from having to do it myself. I plan on spraying primer before it gets too cold, and then deciding on paint when it warms up enough to spray again
Old 12-31-2016, 06:28 PM   #44
Omegadog
Omegadog's Avatar
Thanks Cheap Man! Shaved heads and valve job, new intake manifold, radiator, shroud, overflow tank, water pump, heater core, fan clutch, hoses, sparks and wires, t-stat and wiper motor. When will it end, when will it end? I plan on doing some minimal bondo and priming here in SC when it's not too cold too. Winters are unpredictable here. It can get down to 19 and up to 50 the next day. I plan to paint mine a charcoal metallic in the early spring. Here's a before/after of the rims I did last weekend. I spent a few hours doing them with Rustolium rattle cans and I have some SS beauty rims coming from LMC. A few runs etc. but I'll be repainting often I'm sure...
Rock and roll and Chevrolets...what more need I say?!
My '84 Silverado build progress...
https://www.flickr.com/photos/99009428@N08/
Old 12-31-2016, 08:06 PM   #45
vht
Your doing great! I can relate to a budget build, my K10 project is exactly that. Sell, swap, trade and you name it. Wish I could afford to hire the block sanding out though.
vht is offline   Reply With Quote
Old 01-01-2017, 01:09 PM   #46
rusty76
rusty76's Avatar
I am a low budget kind of guy. If you haven't checked out my low buck build threads thread then take some time. I am posting this one in my thread today. Awesome work and keep on keeping.
My build thread
Crossmembers CC
Old 01-01-2017, 02:30 PM   #47
friscobob
Originally Posted by cheap View Post
Well, patch panels are on their way and so the big steps are coming soon...For paint, is there a good way to do it without a spray gun? any aerosols that are decent? I have a decent spray gun setup if i need to, but i"d like to go the easiest route with a decent result.
Trim roller and foam brushes.
friscobob is offline   Reply With Quote
Old 01-01-2017, 02:38 PM   #48
friscobob
" dual 2.5" exhaust "
You gave up some power there, the bigger the pipe the slower the flow rate. This is an area to trust the factory engineers, unless you go to a bigger engine or higher revs, best stick to stock exhaust SIZE tubing.
Bob
Old 01-01-2017, 04:56 PM   #49
SkinnyG
SkinnyG's Avatar
I painted my entire truck with Tremclad and a roller.
Three coats. Not thinned. Not wet sanded between multiple layers.
Enough orange peel to give you canker sores, but it has been super easy to touch up as the rust continues to work its way through.
Looks good from a distance, and was super cheap.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-01-2017, 08:44 PM   #50
cheap
Bob
Yeah, the duals on the inline 6 were wayyy overkill, but man they sounded good. From the research I've seen on Engine Masters and bu the Hot Rod staff the 'backpressure' and having too much exhaust stuff is a myth, but it's a moot point as I have a 350 with headers into dual 2.5" exhaust.
My local farm supply place has Vansickle tractor enamel for about 20 a gallon, so I think I'll make some test sprays and see how it does.
To SkinnyG, I really like your truck. Your website was my bible while working the shortbed swap I think the roller setup I just can't bring myself to do, there's too many hours in my bodywork for me to be able to have orange peel
