03-24-2016, 10:00 AM | #1 |
brake bleeder problem on 66'
Bleeding my brakes on the 66' (drums) . Rears done, moved to fronts, here's the problem. The bleeder screw is so close to the spindle C that you can not get a wrench on it. The wheel cylinders are NAPA brand, bleeders are metric (10 MM imagine that) Has anybody ran into this problem ?
If you don't like this pound sand ..... |
03-24-2016, 04:10 PM | #2 |
Re: brake bleeder problem on 66'
Have you tried taking your old bleeder and putting it in the new cylinder ? I've done that before and it worked
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
03-24-2016, 05:25 PM | #3 |
unfortunatly I don't have those any more. Do they make extra long bleeders ? I looked at NAPA's web site, but couldn't really tell if their is a differance in length.
03-24-2016, 06:31 PM | #4 |
I have had this problem before. I was able to use a 1/4" drive 10mm metric deep socket.
03-25-2016, 10:36 AM | #5 |
Same problem here and I didn't want to re-use my old rusty ones. Searched all the parts stores and the only one who had any was O Reilly's. H9401-2, pack of two for $3.59. They are identical to originals, about 1 1/2" overall length.
Worked great using a 10mm brake bleeder wrench! |
03-25-2016, 09:54 PM | #6 |
Thanks Rolland - now if I can get mine out without taking everything apart. But it looks like the right side has a little more room than the left.
03-27-2016, 03:48 PM | #7 | |
03-27-2016, 05:03 PM | #8 |
I ended up ordering the russell speed bleeders from summit in the same size.
04-14-2018, 09:02 PM | #9 |
But Found Her 25yrs Later!
Do you remember the part number?
04-17-2018, 10:05 AM | #10 |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
04-17-2018, 02:13 PM | #11 | |
