03-24-2016, 04:44 PM | #1 |
power steering pulley doesn't line up
Hey guys just finished a top end and painted the motor well and the engine. Also got new crank, water pump and alt pulleys in polished aluminum to match the build. Now my power steering pulley doesn't line up. It looks like it needs to come out a quarter of an inch. Are there shims for this? The crank and water pump pulleys are matching set, and I got a chrome alt with its own pulley, so this was by no means a kit with matching parts.
03-24-2016, 05:04 PM | #2 |
Re: power steering pulley doesn't line up
There's only one bolt mounting it, the one to the water pump. So there's nothing to keep the power steering pump from rotating and sitting on the balancer either.
03-24-2016, 05:23 PM | #3 |
After looking at the picture that pump and braket look horrible against the fresh paint and chrome....might be time for an upgrade if anybody knows what will work. Quick fix are welcome too, I'd love to be driving the truck while I get other PS parts of needed
03-24-2016, 06:00 PM | #4 |
It'll Buff Out!
There was a double not stock pulley on mine when I bought it and it wasn't aligned. I bought the original single pulley off a board member and it fit perfect. I remember not being able to find them anywhere local. hopefully someone can chime in and correct me if i'm wrong. I thought only the original singles worked with our brackets. now you stated you changed pulleys. I wonder if that's a problem?
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
03-24-2016, 06:04 PM | #5 |
That is for a later model long water pump set-up. I'm close by and have the assy and brackets you need
Never mind, looking at that again, you already have the long water pump |
03-24-2016, 06:24 PM | #6 |
I mite have to call a vendor because I have the same issue. I got a stock 327 with 80's 305 head's with a long water pump.... need to correct this as well!
03-24-2016, 06:30 PM | #7 | |
03-24-2016, 06:34 PM | #8 |
I just found a polished aluminum PS pump and bracket that mounts on lower driver side, made by March Performance. It looks great, I just wonder if it would line up with the pulleys I have now. It's $120 bucks. Maybe the best way to garauntee aligned pulleys is to get a kit.
03-24-2016, 07:11 PM | #9 |
Ok mr turner , what are you doing ? I thought your next addition was going to be BRAKES and SUSPENSION ? Leave the bling bling chrome and shiny parts until your done with the REAL mechanical issues ! Kids , Sheesh! Hahaha
Posted via Mobile Device |
03-24-2016, 07:33 PM | #10 | |
On a serious note though, I don't understand how this ever stayed off the balancer before the rebuild. It always only had the one mounting bolt to the water pump....weird. Quick fix ideas? PS I'm looking at Gear Vendors (rubbing hands together like I have a PLAN lol) |
03-24-2016, 07:36 PM | #11 |
Pss I've been doing the test drives without power steering, just to clarify. I wasn't TOTALLY off track seeing shiney stuff lol
03-24-2016, 08:10 PM | #12 |
It'll Buff Out!
I would definitely clean up inspect and paint that power steering box now. Take a look at it and see if she has any leaks, as pretty as your motor is I would say now is the time to fix it before you get oil all over it.
Those gear vendors are nice, their shop is only about 10 minutes down the road for me. one day ill bolt one in lol
03-24-2016, 09:03 PM | #13 | |
03-24-2016, 09:05 PM | #14 |
If I go to replace this pump, what do I ask for? The one that came on a 70' c10 doesn't look like the one I have. Would I just get a SBC Saginaw pump?
03-24-2016, 09:55 PM | #15 | |
Time to hit the junk yard by your house , and really all that chrome goodness your chasing requires constant cleaning especially when your cranking that engine into the stratosphere ! Even high quality belts start shedding when the pressure is on and don't over tighten them thinking it will help , they'll just die faster ! A good clean pump and bracket that fits and detailed correctly Using satin black paint always looks better than cheap chrome that starts rusting in a few months ... Remember the timing cover ? Posted via Mobile Device |
03-24-2016, 10:48 PM | #16 | |
I think the problem I'm running into though, is having headers so there are no factory brackets that will work. Is that right or do you know something I don't? I was thinking just get a bracket from eBay that's made for the SBC that doesn't use the exhaust manifold for a mounting point. It's a simple little peice, a lot like the aftermarket alternator brackets actually. Then get the correct pulley for my application. |
03-25-2016, 12:15 AM | #17 | |
If you don't care about it being perfectly correct to the truck, I have had very good luck with Alan Grove brackets. Scroll down and you will find the PS brackets. http://www.alangrovecomponents.com/S...Short_Pump.htm
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
03-25-2016, 01:24 AM | #18 |
I had a similar problem I had a random power steering pump on my truck that leaked, replaced it with what I thought was the same and It was like yours way off. I called and emailed summit a picture just like that and they got me the right pump. I went for a new one with a lifetime warranty. It was $150 but if it ever leaks I get a new one for free
1972 gmc c15 short bed... Sold 1970 chevy custom camper patina daily driver |
03-25-2016, 06:57 AM | #19 |
A good idea for these old trucks is once you have all your bolt on accessories figured out buy an extra set of belts and a basic set of tools needed to change out or replace a thrown belt on the side of the road . . Nothing worse than taking the family for a cruise and having to tow it home over a belt .
03-25-2016, 06:50 PM | #20 |
Well I didn't want to replace anything that still works, so I'm removing the pump and giving it a good cleanup and paint to match the engine. I found a new mounting bracket that looks like it will place the pump further away from the firewall, which is what I need to make the pulleys line up. I got the correct single groove pulley, and that stuff should be here beginning of next week. Hopefully it all comes together and I can be done with everything under the hood for a while, there's a lot needs to be done for front brakes and suspension all around
03-25-2016, 06:53 PM | #21 |
This is the style of mounting bracket I got, and the new pulley looks like this but it's a single groove
03-25-2016, 08:17 PM | #22 | |
Scrapper 1
03-25-2016, 08:20 PM | #23 |
Scrapper 1
this is the ones they use on the NOVA Chevelle Camaro Hate that bracket.Plus if you have a motor mout go bad By by power steering hose to many sharp corners
03-25-2016, 08:58 PM | #24 | |
03-30-2016, 01:51 PM | #25 |
Parts came in and look great. I tried taking the pulley off the old pump and broke it...oh well, this build deserves a new pump anyway The pulley doesn't line up but it's closer than last time. I'm going to shim the mounting bracket to dial it in because it's a keyway pump and pulley, so I don't think your supposed to shim the pulley.
