Old 03-25-2016, 02:27 AM   #3276
Gregski
Gregski's Avatar
Re: Restoring Rusty
I is tired so here are some random pics - push rods and lifters soaking in the Special Sauce!
Gregski is offline   Reply With Quote
Old 03-25-2016, 02:32 AM   #3277
Gregski
Gregski's Avatar
Re: Restoring Rusty
spent about 45 minutes per side chasing the threads in the 17 head bolts per side
since I didn't trust my cheapie tap or chaser what ever it is called, heck there may be even a difference, I just decided to clean an old bolt or two very well with a wire wheel and using mineral spirits so that I wouldn't go in dry I cleaned up all the holes until I could screw in a bolt by hand and unscrew it by hand
clean threads are important because these bad boys will be torques down to spec and we don't want the heads a warpin'
Fun level - 5.8
Old 03-25-2016, 02:38 AM   #3278
Gregski
Gregski's Avatar
Re: Restoring Rusty
I leave you with a question, if I don't plan on using my heater core, do I need to loop the intake manifold to dump directly into the water pump using that short hose about 6 inches or so, or can I just plug that opening in the intake manifold, especially since the matching hole is already plugged in the new water pump,
port in question shown with the screwdriver below
Old 03-25-2016, 04:02 AM   #3279
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Restoring Rusty
Plug it
Old 03-25-2016, 09:08 AM   #3280
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
This beats the hell out of basketball.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-25-2016, 10:12 AM   #3281
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by KQQL IT View Post
Plug it
AMEN brotha! next time could you summarize what you are going to say and not ramble on and on like that, jk, LOL
thanks again
Old 03-25-2016, 10:13 AM   #3282
Gregski
Gregski's Avatar
Re: Restoring Rusty
ha ha, yup
Old 03-25-2016, 10:46 AM   #3283
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
You don't have AC so you may want the option of running the defroster to clear fog off the glass on a spring or winter evening when the air is damp.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-25-2016, 10:59 AM   #3284
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Chaplain View Post
California weather is so good you don't need the heater core...What's gives?
yup, pretty much, plus The Greg don't like cluttered engine bays
Old 03-25-2016, 11:01 AM   #3285
Gregski
Gregski's Avatar
Re: Restoring Rusty
aint that what my long sleeves are for, but you're right, there will be a morning when I will regret it and wish I had heat
Old 03-25-2016, 11:15 AM   #3286
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Run copper hard lines with hoses at the ends. Bead the ends to keep the hoses on.
Maybe;
1 along the frame from the water pump hose to up under the heater box.
1 along the intake to the back of the engine... Or maybe both.
1 possibly 2 along the firewall close to the back of the engine.
Copper can be soldered side by side with a slight bump up at the ends to allow two hoses with clamps side by side.
You can buy formed 90° & 45° heater hoses.
Polished copper could look interesting. Or you could paint em to make them blend.
Old 03-25-2016, 07:41 PM   #3287
Gregski
Gregski's Avatar
Re: Restoring Rusty
Ladies and Gentlemen, today is literally The Greg's wifes birthday, needless to say the garage is off limits, so lets keep this on the downlow shall we, cause if she was to find out she would kill me, but I know in my heart of hearts that if she found out that I was about to try to prime my newly re assembly Chebby with a home made distributor stir stick with the cam gear still on it, she would be even more upset, so what I am trying to say here, in a round and about way, we are doing this here modification for her, wouldn't you agree, it's essentially damn if I do, damn if I don't situtation
Old 03-25-2016, 07:51 PM   #3288
Gregski
Gregski's Avatar
Re: Restoring Rusty
The Power Oilanator 3000
(Patent Pending)
Old 03-25-2016, 09:08 PM   #3289
enaberif
Re: Restoring Rusty
Have fun preoiling.. It takes time a damn good drill.
enaberif is offline   Reply With Quote
Old 03-25-2016, 11:13 PM   #3290
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Nice.
Don't let SWMBO catch ya.
Old 03-26-2016, 10:54 AM   #3291
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
A caution. You got two valve cover breathers, and you like clean engine bays...
HOWEVER
... you *need* a PCV valve on one valve cover. Blow-by puts exhaust gasses in the crankcase. You can either suck them out with a PCV valve, or you can let them condense in the crankcase, in which case they will soon sludge up all the internals on your new engine. Even after 10,000 miles, you can see a huge difference on the internals of an engine with a PCV valve and one without.
You can put it on the passenger-side valve cover, which would put it in the back, and connect it with a short hose to the back of the intake manifold or carb.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 03-26-2016, 03:40 PM   #3292
Will206
Re: Restoring Rusty
HOWEVER
Yea, I just went through this. I was going to do two breathers but after a fair amount of reading decided PCV really is helpful and can extend engine life.
Then the mystery of what PVC to buy...Fram makes a variety of them, but its near impossible to find the specs on them. There's a company that makes a really nice one, but $130 for a PCV is pretty steep for me: http://mewagner.com/?page_id=444
I decided to just go with one of these from Summit: http://www.summitracing.com/parts/sum-440308/
Will206 is offline   Reply With Quote
Old 03-26-2016, 07:03 PM   #3293
Gregski
Gregski's Avatar
Re: Restoring Rusty
HOWEVER
Sir you have finally convinced me, The Greg will run a PCV valve from the valve cover to the base of the carb! ha ha
Old 03-26-2016, 07:10 PM   #3294
Gregski
Gregski's Avatar
Re: Restoring Rusty
The Greg had the Best Day In the Garage Ever !!!
so lets get you some updates...
today was Engine Assembly Day - EAD
check on out my Cam Opener (get it Cam Opener?!)
Old 03-26-2016, 07:16 PM   #3295
Gregski
Gregski's Avatar
Re: Restoring Rusty
GM Chevrolet Performance Hydraulic Flat Tappet Camshaft, Part Number 24502476
Old Cam Lobe Lift - - - - - New Cam Lobe Lift
.260" / .273" - - - - - - - - - - - .290" / .307"
Old Cam Valve Lift - - - - - New Cam Valve Lift
.390" / .410" - - - - - - - - - - - .435" / .460"
... and after a liberal amount of assembly lube, the turkey went in the oven, (no cam bearings were harmed during this operation)
Old 03-26-2016, 07:20 PM   #3296
Gregski
Gregski's Avatar
Re: Restoring Rusty
got the timing set on and the timing marks aligned properly
then the timing cover went on, we used spray on adhesive on both sides of the paper thin timing cover gasket for good measure
Old 03-26-2016, 07:23 PM   #3297
Gregski
Gregski's Avatar
Re: Restoring Rusty
the nice thick Fel-Pro oil pan gasket went on next with smigeons of Ultra Black RTV gasket maker in the corners and in the half circle valleys in the front and rear of the pan
Fun Level so far = 11.6
Remember: not all the oil pan bolts get torqued down the same way the 4 corner ones are more bigger, lol
Old 03-26-2016, 07:25 PM   #3298
Gregski
Gregski's Avatar
Re: Restoring Rusty
then we flipped her over right side up again and slid in the properly lubed up with assembly lube hydraulic flat tapped lifters
Old 03-26-2016, 07:30 PM   #3299
Gregski
Gregski's Avatar
Re: Restoring Rusty
the heads wen ton next and were properly torqued down to 65 ft lbs in three phases
Phase 1 - 20 ft lbs
Phase 2 - 40 ft lbs
Phase 3 - 65 ft lbs
here's a looksie from both the front and the back of the motor
Fun Level temporarily dipped to 10.7 (LOL) as the engine stand wanted to slide all over the garage floor under such high torque, lol
Old 03-26-2016, 07:36 PM   #3300
Gregski
Gregski's Avatar
Re: Restoring Rusty
then when a push came to shove it was time to drop in the push rods
