Old 03-26-2016, 04:49 PM   #1
Donaldo
gauge cluster question
I have a replacement 12 volt fuel gauge for the '51, see pic. should there be some insulation between the center section of the gauge and the housing, or is that to be in contact ?
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 03-27-2016, 02:46 PM   #2
_Ogre
_Ogre's Avatar
Re: gauge cluster question
the gauge should be insulated from the dash
use cardboard, plastic, gasket material or any other insulating material
while this is my volt gauge i used gasket material i had on hand for insulation
shop air compressor timer
Old 03-27-2016, 05:20 PM   #3
Donaldo
Hi Ogre, I have the insulation on the back of the housing as you have, I would like to be sure of the inside of the casing, is that elongated soldered tin piece to be in contact, making it a ground, or isolated like the back of the cluster ?
Thanks, Don
Old 03-27-2016, 11:05 PM   #4
_Ogre
_Ogre's Avatar
my bad, i should have googled it before i posted
yes you need to ground that plate
all analog panel gauges work the same; gas, voltage and oil pressure
12v in, ground and variable ground thru the sending unit
Old 03-27-2016, 11:22 PM   #5
Donaldo
Ok, thank you !
Thanks, Don
