Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 03-26-2016, 07:26 PM   #1
carolinajohndeere
gas mileage
Hi: I just bought a 1972 C50 with a grain dump bed. The brake lines were shot along with some wheel cylinders. Just got all that fixed and started driving the truck. It has a 350 engine, a 4 spped trans., and a 2 speed rear end. The rear end is a 6.50 ratio in hi range.
Anyhow, the truck runs great. The only problem is that it is getting reall bad mileage, less the 5 mpg. I know this is a low geared rear end, but a 6.50 was in a lot of the Chevy trucks.
What has been you experience with gas mileage on one of these. Once I know what I should be getting, I will start digging into the fuel system if needed.
Thanks in advance for your help.
carolinajohndeere is offline   Reply With Quote
Old 03-26-2016, 08:30 PM   #2
South Florida C50
Re: gas mileage
It's never gonna be great, but you can make it better doing a few things that I did to my 1969. I had the same setup as you before I turned it in to a pickup. Try to keep up on the routine maintenance, new plugs, new wires, better air filter,change your distributor to an HEI, if your still using points. And the number 1 thing I did that really helped was upgrade to a high-flow exhaust system! It has to breath better to be more efficient. Night and day difference in the mileage.
South Florida C50 is offline   Reply With Quote
Old 03-26-2016, 10:43 PM   #3
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: gas mileage
Great advice on the Exhaust.
It will sound a whole lot better too, lol.
Also as mentioned, give the engine a good "Super Tune".
I had both, a Flow-thru Exhaust and a Super Tune on a lot of my Chevys and I would get some great mileage out of them.
Also important is "how" you drive it.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 04-03-2016, 06:00 PM   #4
jumpsoffrock
Re: gas mileage
Once I swapped my rear gears from the 6.5:1 to the 4.86:1, I ended up driving it about 70 miles north to pick up a car. Topped off the gas in town, and as soon as I exited freeway again. Doing a rough calc, I got 10mpg. I was very satisfied with that.
I haven't even done a tune up on it! In 25 years! Still running the same plugs, wires, and points that have been sitting on it since my dad was given it in ~1989.
Tare weight is ~8400lbs., 327ci with 2bl rochester, 4-spd, 2-spd rear
P.S. I have new plugs etc, a junkard HEI, the need for a new exhaust, and finally changing to an electric cooling fan coming down the pipes though.
I really can't wait to see what mileage it gets after that.
jumpsoffrock is offline   Reply With Quote
