03-26-2016, 09:53 PM | #1 |
Copper fuel line ??
Am doing some other work and found that the PO had installed copper line from fuel pump to carb - have never seen this before. Am concerned that there may be a down side to copper fuel line due to vibration, heat, etc.
Info or advice?
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
03-26-2016, 10:11 PM | #2 |
Re: Copper fuel line ??
it's been done in some old hot rods, but i'd swap for steel personally.
03-26-2016, 10:38 PM | #3 |
The Older Generation
I have used copper on some of my old hotrods in years past but I agree with jocko. You might try the newer NiCopp line, you can bend it by hand, and another up side is that it doesn't rust..... LockDoc
03-26-2016, 10:47 PM | #4 |
Is it actually copper, or is it NiCopp? I've used the NiCopp stuff for brakes, not fuel, but I guess it would work for that also.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
03-26-2016, 10:54 PM | #5 | |
I used the NiCopp for fuel line and brake lines on the '34 Ford Coupe and for fuel line and transmission coolant lines on the '67 Panel Truck with the LS1/4l60e combo, which carries 58-60 pounds of fuel pressure. It has worked great for me so far.... LockDoc
03-26-2016, 11:02 PM | #6 |
I've installed it before on an old Dodge power wagon I owned. Had a roll of 5/16-3/8? Laying around and used it. I also sheathed it in rubber hose for road protection.
I know copper will split length wise with the line, but figured it would be a long time before that would happen. Early autos used it, internal oil lines, gas and diesel also |
