Old 03-26-2016, 09:59 PM   #1
CCCC
CCCC's Avatar
Push rod hold for fuel pump install on BB
On some small blocks I have used a through hole in the front of the block to insert a bolt (etc) to hold the push rod from camshaft up into its channel (instead of using heavy grease, slip strip, etc). Is there such an opening on the front of BBs?
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 03-27-2016, 10:04 AM   #2
hugger6933
Re: Push rod hold for fuel pump install on BB
I don't remember one being in the front but there is a plug under the fuel pump hole that you can remove to push back the rod.
hugger6933 is offline   Reply With Quote
Old 03-27-2016, 06:50 PM   #3
snipescastle2
snipescastle2's Avatar
Talking Re: Push rod hold for fuel pump install on BB
Just use some wheel bearing grease on the rod, that will hold it for a while.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 04-01-2016, 06:52 PM   #4
CCCC
CCCC's Avatar
Thanks hugger - first time I've done a fuel pump on a BB - found the plug. Helpful.
CCCC
Old 04-01-2016, 09:44 PM   #5
Rod Run
Rod Run's Avatar
Ben
I've also used thicker type grease in the past
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
