Old 03-27-2016, 10:13 AM   #1
tkennedy
Stepside Rims
Does anyone out there have pics of a stepside with Ridler rims (695) 18x8s for the front and 20x10s for the rear? I just placed an order for my truck but nervous about the look.
tkennedy is offline   Reply With Quote
Old 03-28-2016, 04:58 PM   #2
nate68
Re: Stepside Rims
A 10" wide rear tire won't fit on a stepside without rubbing (unless you tub)
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 03-28-2016, 07:29 PM   #3
BugzC10
BugzC10's Avatar
Re: Stepside Rims
Originally Posted by nate68 View Post
a 10" wide rear tire won't fit on a stepside without rubbing (unless you tub)
x2
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-29-2016, 08:20 AM   #4
68Stepbed
68Stepbed's Avatar
Re: Stepside Rims
As long as the backspacing is right and you don't get the rear tire too wide, the 10" wheel will be ok. You may be limited to a 275 width tire, though.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-29-2016, 08:22 AM   #5
BugzC10
BugzC10's Avatar
Re: Stepside Rims
Is that dependent on what width axle he has?
Old 03-29-2016, 08:27 AM   #6
Mike C
Mike C's Avatar
Re: Stepside Rims
Axle doesn't matter as long as the offset is right.
On my 69 short step I have a 17x9 rear wheel with 5" backspace. I have a swapped in axle from a '72 in 5 lug. I'm running a 275 55 17 tire and have about a fingers width clearance on both inside and outside of tire. That's pretty much the limit to what fits. You might go to a 285 in a 40 series profile, but keeping the height near 29" was important to me.
My truck is dropped 7" in the rear with a DJM flip kit on the leafs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-29-2016, 09:30 AM   #7
Henner
Re: Stepside Rims
Ran 8.5" rims all the way around with 4.75 BS, 245/45/20 on front and 275/45/20 on the rear.
Name:  29-Mar-2016 08-28 .jpg
Henner is offline   Reply With Quote
Old 03-29-2016, 09:38 AM   #8
Henner
Re: Stepside Rims
I bolted these up then removed them and sold them. I now have 20" Rally wheels. On those I went 8.5" with 5.0 BS and rear 9.5" with 5.75 BS.
Old 03-30-2016, 08:17 PM   #9
tkennedy
Re: Stepside Rims
The wheels just came in but I'm waiting on tires. A friend said that he has the same wheels but had to modify the inside of the rear fenders.
Old 03-31-2016, 08:30 AM   #10
68Stepbed
68Stepbed's Avatar
Re: Stepside Rims
tkennedy, what year is your truck?
Matt
Old 03-31-2016, 10:31 AM   #11
Henner
Re: Stepside Rims
Just put the new Rally wheels on (didn't install center caps). I am running a 9.5" wheel out back with 5.75 BS and can air it out and clear fender inside and out.
Name:  31-Mar-2016 09-2125 .jpg
Old 03-31-2016, 01:22 PM   #12
BugzC10
BugzC10's Avatar
Re: Stepside Rims
Attachment 1516836
What's your axle width? Backing plate to backing plate...
And what's your tire size?
Old 03-31-2016, 02:27 PM   #13
Henner
Re: Stepside Rims
I have the 72 rear end, I can't remember the exact measurement but it's wider than the original 68. Front tires are 245/45/20, rear 275/45/20
