Old 03-06-2004, 05:23 PM   #1
67sss
67sss's Avatar
72 Longhorn Camper Special 30 ???
saw one today at the wrecking yard as I was getting a grille. Not much left of the truck, was a BB 400,a/c, Green, ps,pb. Any special part I should look for if I go back? sorry no pics.
67sss is offline   Reply With Quote
Old 03-06-2004, 05:39 PM   #2
Joesjunk
Joesjunk's Avatar
I would be interested in the fender emblems if they say Custom/30 or Cheyenne/30
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 03-06-2004, 06:05 PM   #3
Pilgrim
Would be interested in speed warning if it has one.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 03-06-2004, 06:10 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Pilgrim, just and FYI. Speedwarnings weren't installed in trucks after 1969. If it has one it was added by a PO. Some pre-70 GM cars had them to, most notably Camaros. Also pre-70 series 40-60 trucks may have them too, incase you go junkyarding.
Back on topic, if its and auto and has the shift linkage, I may be interested.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-06-2004, 06:23 PM   #5
Rod
BB manifold heat shield off cab?
Motor mounts?
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-06-2004, 09:10 PM   #6
67sss
67sss's Avatar
might have to go back,CPNE: what auto linkage do you need?also will have to check on emblems and on BB mounts and sheilds for Rod and Joesjunk.
Old 03-06-2004, 11:29 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
There are 3 pieces. The rod from the column, the "swivel" bracket the rod attaches to, and most important is the frame bracket the swivel bracket pivots on. Also the "C" shaped bracket on the tranny if available. Of the pieces the most important is the frame bracket, the other pieces are the same as a small block and I can locate elsewhere. Thanks
Old 03-17-2004, 01:21 AM   #8
67sss
67sss's Avatar
CPNE-no frame bracket, rest of stuff I just left since it's the same as sb stuff
Rod-no heat shield or mm
Joesjunk-posted pic for you.
Old 03-17-2004, 05:13 AM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I want the Longhorn emblems if they still have them.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
