Old 03-06-2004, 07:39 PM   #1
72step
72step's Avatar
Question correct backspacing on 2wd 1/2ton stepper???
I'm in the process of ordering me some wheels, but who out there know's the correct standard backspacing on the rear of a stepside on a 15x8 inch wheel with a stock diffeential? I currently have 15x10's with 4.5" offset, and the tire is like 3/4" from the bed, and I can't afford to go out anymore because the tire would stick out of the fender, therefore have decided on some 15x8 torque thrust II's Thanks in advance!!!
72step is offline   Reply With Quote
Old 03-06-2004, 09:52 PM   #2
72step
72step's Avatar
anyone????
Old 03-06-2004, 10:15 PM   #3
djracer
djracer's Avatar
If the tens fit i'd stay with 10's but an 8 with 3.5 inch of backspace should be the same offset you have now because you are taking an inch of each side of the wheel!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-07-2004, 12:30 AM   #4
gr8scott51
gr8scott51's Avatar
4-1/2" backspace is stock on 15 x 8 rims. My tires are about 3/4" from the box, too. The local Les Schwab tire store told me the torque thrusts wouldn't fit, but I never tried.
Good luck, scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 03-07-2004, 02:16 AM   #5
72step
72step's Avatar
Thanks. I think the 15x8 torque thrusts with the 3.5" backspace will work. Any other experiences?
Old 03-07-2004, 07:33 PM   #6
FirstGen
Just Don't Stop!
FirstGen's Avatar
Mathmatically, going from a 10" wide wheel with 4.5 backspace to a 8" wheel with 3.5 backspace will work out to have exactly one inch more clearance on each side of the new 8" wheel... so if you had 3/4 inch on each side clearance on the 10" wheel you will have 1.75" on each side of the 8" wheel.
I'd like to see some pictures of the 10" that you have now if you have any...
Good Luck
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 03-08-2004, 09:46 AM   #7
Bowtie67
Bowtie67's Avatar
I have been running another type of wheel when ordering my new Tourque Thrust wheels and I needed check my old ones, my old ones where 9.5 x 15, and they had a backspace of 3.75 inches, with the tires 295/50 they would just barely hit the inner bed panel. 67 stepside I added a 1/4 spacer to resolve problem. my new wheels I ordered a 10x15 with a 3.5in backspace. hope that helps.
Bowtie67 is offline   Reply With Quote
Old 03-08-2004, 12:18 PM   #8
72step
72step's Avatar
Here's a pic of my truck currently. Let's see if this works.
Old 03-08-2004, 12:21 PM   #9
72step
72step's Avatar
Firstgen, naw, I can't seem to shrink my pics down enough, sorry. Give me your email, and I'll email ya a pic.
Old 03-08-2004, 06:26 PM   #10
FirstGen
Just Don't Stop!
FirstGen's Avatar
ok thanks!
unlimitedlandscape@hotmail.com
TT LSA/6L90e/9"
