Old 03-28-2016, 08:57 PM   #1
BlueJeep
BlueJeep's Avatar
Vulcanized whitewall question
For those of you who have wide whites that were vulcanized to the tires (Hurst, Diamondback, etc.), have you ever heard of a "bubble" under the white? I have some tires that I purchased from Hurst just before they went out of business. I had the tires mounted and there appears to be a small piece of the whitewall that wasn't adhered properly and I have a resulting bubble. It did not appear until the tire was mounted, and I'm thinking the pressure of being seated on the rim is pushing the white out in this location. I'm wondering if there is anything I can do about it? Ordinarily I would have contacted the manufacturer....but....I can't.
Thanks for any feedback you might have.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-29-2016, 12:06 AM   #2
Foot Stomper
Foot Stomper's Avatar
Re: Vulcanized whitewall question
I'd recommend getting in touch with Coker tires. I acknowledge they are not Coker tires, but they are approachable and knowledgeable about manufacturing wide white walls (in my experience with them.)
They might be able to explain the manufacturing process and offer some solutions in hopes that you'd be a future happy customer.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 03-29-2016, 06:19 AM   #3
tsmith8
is it only the white wall that is bubbling or is that bulge starting to appear in the tire itself??
If a tire is not "soaped" correctly before being put on the rim it could cause damage in the tire. The damage can result in "bulges" appearing in the sidewall.
tsmith8 is offline   Reply With Quote
Old 03-29-2016, 02:38 PM   #4
mrf1002u
Jack it up, air it down, tuck the loose part under the lip of the rim, air it back up. If it stays, fine, if not it may have air leaking into it. In that case, prick it with a pin, if it leaks all the time, replace the tire, it wasn't safe in that case anyway.
Larry W.
mrf1002u is offline   Reply With Quote
Old 03-29-2016, 10:30 PM   #5
BlueJeep
BlueJeep's Avatar
It's just the white wall coming loose from the "donor tire" in that spot, no issues with the tire itself or losing air. For those who don't know, Hurst took off the shelf Hankook tires and vulcanized the whitewalls on them. Part of the whitewall tucks in the bead of the rim, and that's what is pushing it out in the "bubble". I can push it in but it does not stay, hence I believe I need some way to "adhere" it back to the tire.
Thanks for the suggestions, and keep 'em coming!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-30-2016, 12:07 AM   #6
mrf1002u
If you can get it in behind it, try some rubber cement.
Larry W.
Old 03-30-2016, 01:23 AM   #7
mr48chev
mr48chev's Avatar
That's what I would do. pull the tire back off the rim and find the right rubber cement an glue the
It could have been a dirty spot on the tire when they put the rubber on it but it also could have been damaged when it was mounted. As TSmith8 said above you don't wan to be stingy with the tire soap when you are mounting tires and especially wide whites.
My ongoing truck projects:
