Old 03-29-2016, 06:30 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question Trans temp
Just wondering what temps you guy's see typically on your 4l80e transmissions. Mine has been pretty good over the past 2 years but every now and then it will get about 200 without anything out of the norm. No trailer pulling at all just cruising.
I'm going by the Scan Gauge 2 I have hooked to the ECU for the temperature reading.
This winter when driving it wouldn't hardly get over 100*.
The temp probe is inside the pan correct if I remember right.
Wondering if a synthetic would help any?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-29-2016, 08:37 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Trans temp
What type of oil cooler do you have? Did you log the type of driving you were doing when you saw the elevated temps (speeds, traffic conditions, etc.)? if it spent a lot of time out of lock up, it can get warmer (slower speeds, stop-and-go, etc.).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-29-2016, 09:56 AM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: Trans temp
It was always just cruising down the interstate at 70-80 MPH.
I have both cooler's internal and external. It would stay right at 195 200 which I know is ok but just wondering why it would climb.
The water temp would be about 5*-10* warmer than trans temp. Just wondering if the synthetic would be worth the price.
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid
Cold-Temperature Fluidity
Cold, thick automatic transmission fluid lengthens shift times and reduces fuel economy. Signature Series Synthetic ATF is wax-free and delivers extraordinary cold-flow properties (< -60°F pour point). It helps improve shift response, energy efficiency and warm-up times.
Old 03-29-2016, 10:29 PM   #4
Robznob11
Robznob11's Avatar
Re: Trans temp
Really the only thing I could think of that would make it climb out of the norm is the lockup or lack of. When your cruising part throttle it should go into lockup, save gas and reduce heat from slipping. Of course that feature is controlled by the computer and modifiable by your tuner. If your tcc brake switch was malfunctioning it could cause issues with that. But at 200 i bet it's fine.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
