Old 03-29-2016, 06:29 PM   #1
Jrainman
Jrainman's Avatar
Master Cylinder ID help
Just picked up a 68 SWB ,The PO did a 5 lug disc brake conversion at some point, The master cylinder is leaking from where it bolts to the booster and also the cap gasket .
I need to replace this master cylinder but need help on the Identification of it .
Jrainman is offline   Reply With Quote
Old 03-29-2016, 07:03 PM   #2
swamp rat
swamp rat's Avatar
Re: Master Cylinder ID help
Just match it at the parts place being as they will want a core, or take your pic's with you and check it that way.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-29-2016, 07:04 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Master Cylinder ID help
Go to the parts store and ask for a Disc/drum master for a 71 are 72 either should work just fine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
