03-31-2016, 09:30 PM | #1 |
Complete 77 dually trim with the yellow stripe including wide tailgate band
SOLD I bought this bed for a 86 so I'm not using the trim its off a 77 so it has the yellow paint stripe in the trim its a complete set upper & lower trim with the aluminum pieces that set against the dually fender (4 pieces) including the tailgate trim upper & lower & wide tailgate band just needs cleaned up all pieces have no dings in them including the band and painted stripe is decent I would like to sell this as a complete set as of now$400.00 shipped lower 48 thanks Jeff
03-31-2016, 09:31 PM | #2 |
Re: Complete 77 dually trim with the yellow stripe including wide tailgate band
Another
03-31-2016, 09:32 PM | #3 |
Pic3
03-31-2016, 09:34 PM | #4 |
Tailgate
03-31-2016, 09:46 PM | #5 |
If you decide to split up I'll take the fender pieces.
Nate
Current Project: 1990 V3500 CC dually. |
04-01-2016, 12:21 PM | #6 |
Nate if I decide to split it up I'll let you know but right now I'd like to sell as a package or all the trim as one and the tailgate band separate thanks Jeff
04-01-2016, 01:05 PM | #7 |
What would you want for all the trim separate from the tailgate band?
Nate
04-01-2016, 06:24 PM | #8 |
I'd do $250.00 shipped on the trim without the band
04-01-2016, 06:29 PM | #9 |
Jeff, If you haven't pulled it off yet, I strongly suggest getting a good penetrating oil on the studs for the cast aluminum pieces. They are known for breaking easily. This happens even on Arizona trucks. I have 2 sets of those pieces and of the 8 pieces less than half came off without a broken stud and these WERE sprayed down. They just didn't have days to sit.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
04-01-2016, 06:42 PM | #10 |
Thanks for the heads up I haven't removed them yet I guess I should start soaking them thanks again Jeff
04-01-2016, 07:09 PM | #11 |
No problem! I was super careful and still broke studs. The part the nut attaches to is really small diameter and breaks easily. The stud is stepped and the part that threads into the aluminum is a larger diameter
04-02-2016, 04:02 PM | #12 |
Bump
04-05-2016, 08:56 PM | #13 |
Bump
04-08-2016, 05:40 PM | #14 |
Bump
04-16-2016, 11:36 AM | #15 |
Bump
05-21-2016, 10:02 PM | #16 |
Sold
