Old 04-01-2016, 04:03 PM   #1
60-66
60-66's Avatar
The Chevrolet and GMC Hubcap thread
The Hubcap Thread
Here are several examples of most of the 1960-1966 Chevrolet hubcaps by year, size and GM part number. Included are the G series hubcaps for 13 inch wheels, both 1/2 ton styles , clip and nub, along with 4x4 hubcaps and the 20 and 30 series truck hubcaps with measurements. Also some comparisons to reproduction hubcaps for 1966. If there is something written by mistake please let me know so it can be corrected.
Definition of terms, "Clip" and "Nub". You will see these terms used often in this thread. "Clip" for this thread refers to the type of rim the particular hubcap fits on and fastens to. These rims use clips that are riveted to the rim. Two different size inner rings were used inside the hubcap. 1/2 ton 6 lug, clip rims came in 15,16 and 17.5 diameter and used a 7 5/8 inside diameter hubcap. 3/4 to 1 ton clip 8 lug rims came in 15,16,17,17.5 and 19.5 diameter and used a 8 3/4 inside diameter hubcap. The term "Nub" is for the more common rim and hubcap where the hubcap fits over 3 nubs on 1961-1966 rims. Those rims came in 15 and 16 inch diameter and used a 10 1/8 inside diameter hubcap.
Corvairs come into this thread also. From my limited research of this model , 1961 1962 1963 Corvair Rampside trucks used the same hubcap as 1961-1963 C10 pickups. Corvairs however used a 14 inch "nub" wheel. 1964 Corvair rampside trucks also used the 1964 C10 hubcaps. 1964-1966 introduced G series and used a 13 inch rim and hubcap with the option of a 14 inch rim and the same hubcap as a C10. If theres any Corvair or G series enthusiasts that can shed more light here it might prove useful.
This first picture represents, almost, one of each hubcap available for 1960-1966. There are a few missing that I haven't found but for the most part each year has an example including the G-10 hubcaps for 13 inch wheels.
1960 Full wheel cover for 1/2 ton , same as 1956 Chevy car. Pictures courtesy of Ebay.
For 1960, Chevrolet carried over the same hubcap from 1957, 1958 and 1959 trucks. From left to right in the first picture; 1) 3/4 ton 4x4 front GM PT #3765837; 2)1957-1960 3/4-1 ton painted GM PT #3743591; 3) 1957-1960 3/4 ton-1 Ton Chrome GM PT #3743592; 4) 1957-1960 1/2 Ton 4x4 painted GM PT #3765832; 5) 1957-1960 1/2 ton painted GM PT # 3734031; 6) 1957-1960 1/2 ton Chrome GM PT # 3734032 .
Some comparison photos of the 1960 1/2 Ton VS 1960 3/4-1 ton hubcaps.
1960 4x4 Center hole measurement 1/2 ton .
1960 4x4 Center hole measurement 3/4 ton .
1961, 1962 and 1963 seems to be the years Chevrolet had the most hubcaps, all with different applications.
From top left to right. 1st Hubcap is technically a 1962-1963 GMC because of the red paint and carries a GMC only PT#. Chevy would have been solid white and it was used from 1961 to 1962 ONLY, GM PT # 3781648. This hubcap is a 1/2 ton Clip style 4x4 hubcap; 2) is a 1961-1963 painted 1/2 ton clip GM PT #3781650; 3) is a 1961-1963 chrome 1/2 ton clip GM PT #3781675; 4) is a 1961-1962 Chevy 4x4 1/2 ton NUB style hubcap GM PT #3781648; 5) is a 1961-1963 1/2 ton painted NUB GM PT #3780114 and 6) is a chrome 1961-1963 1/2 ton NUB GM PT #3780115.
Second row Left to right; 1) 1961-1963 3/4-1 ton chrome GM PT #3781676; 2) is a 1961-1963 3/4-1 ton painted GM PT #3781651 and 3) is a 1961-1962 3/4 ton 4x4 GM PT #3781652.
(For GMC only, the 4x4 hubcaps shown here are from 1962-1963 , Chevy used the 4x4 hubcap for 1961 and 1962 only. 1963 and up Chevy 4x4 trucks came without hubcaps.)
Same order as above but rear view.
1961, 1962, 1963 Half Ton Nub
1961, 1962, 1963 1/2 ton clip
1961, 1962, 1963 3/4 1 ton clip
Size height difference between 1/2 nub , 1/2 ton clip and 3/4-1 ton clip hubcaps.
1961, 1962 4x4 center hole 3/4 ton.
1961, 1962 4x4 center hole 1/2 ton.
For 1964 to 1965 Chevrolet hubcaps, the Chevrolet parts book refers to these as "first design" . I believe its been said that for 1966 they strengthened the hubcap with the ridge around the outer edge of the center triangular part of the hubcap.
1964-1965 top left to right. 1) 1964-1965 3/4-1 ton painted GM PT #3875621; 2) 1964-1965 3/4-1 ton chrome GM PT # 3875622; (empty space three NO PICTURE 1964-1965 1/2 ton painted clip GM PT # 3839984); 4) is a 1964-1965 1/2 ton clip chrome GM PT #3839982; 5) 1964-1965 painted nub GM PT #3839978; 6) 1964-1965 chrome Nub GM PT # 3839983. Bottom right is a 1964 1965 G-10 Chrome hubcap GM PT # 3848661 with the painted version being 3843809.
1964-1965 Rear view.
1964 1965 smooth face as compared to 1966 with ridge
1964 1965 G-10 13 inch hubcap GM PT #3843809 painted, 3848661 chrome .
G-10 Hubcap compared to C10 hubcap.
The 1966 hubcap is a one year only hubcap . The 1966 GM parts book refers to these as "Second design" . The newer the parts book you look in, these 1966 part numbers group 1964-1965 and 1966 as one hubcap. However that is not the way these trucks came off the assembly line but was GMs way of cutting "cost" , maybe and substituting one part for another. The parts history book shows one of the 1964 1965 part numbers was superseded by the 1966 hubcap as early as July of 1966 .
Below are all the 1966 hubcaps; 1) 1966 C20 C30 Painted GM PT #3875621; 2) 1966 C20 C30 Chrome GM PT #3875622; 3) 1966 C10 Clip Painted GM PT #3875625; 4) 1966 C10 Clip Chrome GM PT # 3875623; 5) 1966 C10 NUB painted GM PT#3875620; 6) 1966 C10 NUB Chrome GM PT # 3875624 . Bottom from Left to right; 7) 1966 G-10 Chrome for 13 inch wheels 3875630; 8) 1966 G-10 Painted for 13 inch wheels 3875631; 9) Bottom far right is the current reproduction C10 hubcap, see bottom of post for more information.
Rear view of 1966 hubcaps same order as above.
1966 C20 C30 Hubcap measurement.
1966 C10 Clip style hubcap measurement.
1966 C10 NUB style hubcap measurement
1966 G-10 Van hubcap measurement.
1966 Half ton Nub hubcaps. NOS GM on the left compared to current reproduction on the right. The hubcap on the far right, the bowtie "wings" are considerably shorter top to bottom and the center square is taller. The overall stamping is more squared off and has sharper corners. This reproduction hubcap is still chrome over brass like the original chrome hubcaps. It should be mentioned that none of the chrome hubcaps were Stainless steel in this 1960-1966 era. All of the painted hubcaps are steel.
Here is another example of a second reproduction hubcap in the center of the picture below. Its a much closer version but its been discontinued now for roughly ten years. Here's a comparison of all three. I measured them with a dial caliper. From left to right; 1) original on left; 2) the "Good" reproduction in the center and 3) the currently available hubcap far right.
For the bowtie "wings" I will call them:
1) Original measures .593
2) GOOD reproduction .500
3) reproduction .463
Center of the bowtie or center square:
1) Original measures .890 tall
2) GOOD reproduction .820 tall
3) Current reproduction .992 tall
Now you can see why the one on the far right is so disproportionate to the others. Also notice the ridge around the center is more rounded on the first two, compared to the one on the far right .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-01-2016, 04:03 PM   #2
60-66
60-66's Avatar
Re: The Chevrolet and GMC Hubcap thread
Gmc next soon !
Old 04-01-2016, 04:54 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Great info.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-01-2016, 05:06 PM   #4
undertaker72
undertaker72's Avatar
great info , thats hubcap porn right there ill be posting you a pic of a 3839984 suposed nos , self scrathes but you will have a pic
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 04-01-2016, 05:26 PM   #5
60-66
60-66's Avatar
the worst part is , I have the hubcap and cant find it ?
Old 04-01-2016, 05:37 PM   #6
undertaker72
i know how that is , thats some nice info and a nice collection
I aint nobody DORK
Old 04-01-2016, 05:42 PM   #7
undertaker72
here you go
I aint nobody DORK
Old 04-01-2016, 05:43 PM   #8
undertaker72
here you go
soory the pics rotated i snaped with telly
I aint nobody DORK
Old 04-01-2016, 06:45 PM   #9
60-66
60-66's Avatar
That's it ! That's a rare hubcap undertaker72 . Thanks for posting.
Old 04-01-2016, 06:58 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
This is a GREAT thread!
Keith
Convert to disc brakes.
Old 04-01-2016, 07:01 PM   #11
Lugnutz65
Lugnutz65's Avatar
I don't want to clutter a nice thread with pics that aren't relevant, but I bought a 1966 parts truck with these interesting hubcaps. They push right on to the original 3 bump wheels (however the rear wheels on this truck seem to have been modified).
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-01-2016, 07:12 PM   #12
60-66
60-66's Avatar
Those baby moon bowtie caps are early 70s Chevy. No worries on posting lugnuts65 . Post what ever you like about factory type hubcaps and rims.
Old 04-01-2016, 08:22 PM   #13
jdl71
jdl71's Avatar
So this should put an end to all the hubcap question threads, right?
Seriously, awesome info thank you so much!
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 04-01-2016, 09:16 PM   #14
DPowers
One foot in front of the other
DPowers's Avatar
Looks like FAQ worthy info right there.
DPowers is offline   Reply With Quote
Old 04-01-2016, 10:23 PM   #15
sodly
sodly's Avatar
BIG props to 60-66 for this comprehensive and accurate historical information. It's great to get the real scoop on how these trucks really were when new.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 04-02-2016, 10:09 AM   #16
C/10 King
C/10 King's Avatar
X2222222! Thanks so much! Great info!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 04-05-2016, 11:17 AM   #17
1963c-10
1963c-10's Avatar
Do we know if the 4wd 61-63 caps were available in the deluxe version? The only ones I have seen so far were painted.
And great thread. Thanks for the time and sharing the pics!!
1964 Short bed trailer
Old 04-05-2016, 11:39 AM   #18
60-66
60-66's Avatar
I hope it helps. Thank you !
Thank you !
Thanks Sodly ! and thank you for your suggestions .
Thank you !
Thank you 1963c-10. IF they did ? The 1961 GM parts book is not showing it in chrome , just painted. While the style is 1961-1963, all of the 4WD reference whether its front or rear hubcaps , the books say 1961 and 1962 only. GMC now, I have found chrome caps and numbers for both 1960-1961 style and 1962-1963 style 4x4 front hubcaps. Hope to have that part of the thread updated soon. Might need to find 1961 1962 Chevy 4x4 literature.
Old 04-05-2016, 11:37 PM   #19
corvettejim1968
corvettejim1968's Avatar
im so glad you did this. thank you for educating us
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 04-06-2016, 12:13 AM   #20
oem4me
There is only ONE guy that I know that could pull off a thread like this while including photos like the one below. That's a lot of NOS right there!
Well done Jon!
Old 04-06-2016, 06:36 AM   #21
clemdaddy
clemdaddy's Avatar
thanks a bunch… great info and quite a collection you've got.
clemdaddy is offline   Reply With Quote
Old 04-06-2016, 09:34 AM   #22
63 & 64 Bowties
and a few others
Great info. Thanks for a great write-up. I added a link to this thread into the faq sticky.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 04-06-2016, 09:48 AM   #23
cru_zn_29
cru_zn_29's Avatar
Thanks Jon for the hubcap lesson great info. I have never see that many NOS in one picture in my life.
cru_zn_29 is offline   Reply With Quote
Old 04-06-2016, 10:18 AM   #24
60-66
60-66's Avatar
Your welcome Jim !
Well done Jon!
Aww shucks Bruce , I have to say that much of the knowledge learned came from many different members here, reading different posts and fact checking . Not all of it is NOS though , Just trying to show how many different caps there actually are and there's still some missing.
Thank you Clem !
Thanks !
Collect... hoard , collect, hoard. Something like that. I love trucks ! Thanks cru_zn_29.
Preparing for the GMC section that will be posted in post number two so it runs in order .It will be a few weeks yet , very busy right now with other things but heres a sample.
Old 04-06-2016, 02:49 PM   #25
Very useful thread, thank you.
