Old 04-02-2016, 06:54 PM   #1
Vinny14
1983 Scottsdale fuel issue
She idles fine and drives fine but once I hit around 50+ she starts to choke and feels like the engine is "pausing" but once I let off the gas she is fine. What's the issue?
Vinny14 is offline   Reply With Quote
Old 04-02-2016, 06:55 PM   #2
Vinny14
Originally Posted by Vinny14 View Post
She idles fine and drives fine but once I hit around 50+ she starts to choke and feels like the engine is "pausing" but once I let off the gas she is fine. What's the issue? I'm thinking something with fuel. My fuel filter is cross threaded on my carb but that had been like that for awhile. The issue just started about two weeks ago.
Old 04-02-2016, 09:11 PM   #3
LBJ
Re: 1983 Scottsdale fuel issue
Sounds like several things. Fuel cap could be plugged and not allowing proper venting of the tank. It is supposed to allow into the tank, but not allow gas out of the tank. They get dusty and dirty and corroded etc over the years. A vacuum will build up in the tank and then the fuel pump won't overcome the vacuum. Tank has gotta vent. Gas caps are cheap. Rubber gasket is old and brittle if gas cap is old anyway. Try that.
Also, your rubber fuel line between the fuel pump and the chassis steel line may have a small hole or a tear and she's sucking air under acceleration. Check that. Fuel filter could be dirty, but not as likely as the gas cap being bad. Try the easy things first before replacing the fuel pump.
LBJ is offline   Reply With Quote
Old 04-03-2016, 07:24 PM   #4
Vinny14
I will definitely try those out and keep you posted! Thanks!
Old 04-04-2016, 11:42 AM   #5
Oberon67
Also, if you have installed an inline fuel filter in the fuel line, check that. It could be clogged.
Oberon67 is offline   Reply With Quote
Old 04-04-2016, 03:51 PM   #6
Vinny14
Do you think running a fuel cleaner would help?
Old 04-04-2016, 04:11 PM   #7
Chrispbrown36
I don't think it would hurt, but don't expect a miracle.
Chrispbrown36 is offline   Reply With Quote
Old 04-04-2016, 04:13 PM   #8
Oberon67
I'm guessing not.
If the problem is that you've got a leak and it's sucking air, then the cleaner won't help that. And if your problem is that you've got a clogged fuel filter, the clog is probably due to rust or other undissolvable particulates, and the cleaner won't help that either.
Old 04-06-2016, 12:22 AM   #9
Vinny14
Well I drive it to the gym and back and noticed a heavy fuel smell and checked under the truck and was leaking heavily from the front of the engine near the header.
Old 04-06-2016, 12:25 AM   #10
Vinny14
Better picture
Old 04-06-2016, 05:41 AM   #11
Oberon67
Better picture
Bingo.
I'm guessing you've got a failed fuel pump diaphragm and your fuel pump is blowing gas and sucking air under load... but whatever is leaking, I'm strongly inclined to think that's the problem.
Old 04-06-2016, 03:32 PM   #12
Vinny14
Originally Posted by Oberon67 View Post
Bingo.
I have a good feeling on this also people the issue. Now I have a issue on getting my driveway to not smell like gas haha
