Old 04-04-2016, 05:52 PM   #1
Willv
Willv's Avatar
carburetor - does it really matter
I want to replace my carb - 2029223 on my 69 CST/10 350 engine AT with another Rochester rebuilt carb. Only problem is that I can't find another freshly rebuilt 2029223 on line, not even a 2029224. My question is, does is really matter if the carb is not the same #s? As long as the linkage is correct, and that the choke be the same, right? Of course it would have to mount correctly. Couldn't I just plug some of the vacuum ports if the new carb came with more than what mine brings. Oh.. and I don't want to rebuild mine, I need my truck and can't wait for someone to rebuild my carb. Thanks.. Will
Willv is offline   Reply With Quote
Old 04-04-2016, 06:58 PM   #2
truckster
truckster's Avatar
Re: carburetor - does it really matter
The number isn't critical, as long as it has the fuel inlet in the same location. Make sure you get one for an automatic transmission, as you'll need the kickdown. You might even want to upgrade to a later year to get the electric choke (I think 76-up). Make sure the rebuilder knows what engine you're putting it on so they can jet it correctly.
truckster is offline   Reply With Quote
Old 04-04-2016, 07:43 PM   #3
tdangle
tdangle's Avatar
Not to hijack this thread, but as further clarification on the op question. Can you put the jets, metering rods, etc out of the original carb in another q-jet body and have a carb that is calibrated to your engine?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 04-04-2016, 07:48 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Yes, as long as everything is good like well plugs and accelerator pump, tight throttle shaft bushings, etc. in the replacement carb...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-04-2016, 08:47 PM   #5
52napco
Send ur carb to the carb doctor in pa. It's the best $250 I've spent
52napco is offline   Reply With Quote
Old 04-06-2016, 01:22 AM   #6
mike16
is your carb correct or even origonal for your truck? dont get rid of it if it is, and keep it untill the new one proves its worth and pay with a credit card and state the replacement value if your carb gets "lost". some rebuilders are reputable some are not....bee carfull.
mike16 is offline   Reply With Quote
Old 04-06-2016, 06:10 AM   #7
I don't mess with rebuilding cards because I have a shop that does great rebuilds for very reasonable price. Pull it off, drop it off, put it on, and go. Same carb stays with the truck. But I have switched them around for years never paying attention to numbers. There are different CFM Q-Jets, so watch out for that. My swapping has been 350 truck to 350 truck
Old 04-06-2016, 07:22 AM   #8
67 chevelle
67 chevelle's Avatar
I believe , most q-jets are 750s , the exception being a pontiac or olds specific , that is 850 cfm , and of coarse the old sqarebores that were 500 cfm
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-06-2016, 07:29 AM   #9
52napco
Local shop wanted $165 to rebuild. Bob stone replated everything ,rebushed throttle shaft
and paid return freight for $250.
