Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-04-2016, 10:16 PM   #1
gmachinz
NEW power mirror harness available!
This NEW harness is designed for use with those who want to upgrade to the G-series van dumbo power mirrors or the 1991 Suburban/K5 black plastic power mirrors on any 78-up style square. This can also be used on 73-77 trucks but I'd need to know up front the year (if older than 78) since the fuse panel connectors are different.
This is the harness only-it DOES NOT include the switch....you need to source a 1991 Suburban power mirror switch with this harness because you'll need to install it in your drivers door panel similar to the factory location in the 91 Burbs. If you want to relocate the switch you can also use the van style switch too. This harness saves you time/aggravation separating out a full harness from a junkyard donor truck. This harness is not available through GM (obsolete part) and I have a small supply of the correct Delphi connectors to build these for awhile now.
Harness price is $149. I do from time to time stock various switches, power mirrors (both styles) as well as NICE 1991 Suburban door glass/hardware and even NOS weatherstrip seals and channel guides so if you need something to go with a replacement harness, just ask I may have it!
gmachinz is offline   Reply With Quote
