04-05-2016, 10:17 AM | #2201 |
It's Better With Nitro
Re: What did you do to your truck today part III
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
04-06-2016, 01:17 AM | #2202 |
Rear LED lights are in....
04-06-2016, 07:54 AM | #2203 |
I had it towed home. Pretty sure the alternator is dead.
04-06-2016, 01:33 PM | #2204 |
Cruised it to work with my buddy and his 82. Another friend drove his 72.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
04-07-2016, 04:41 PM | #2205 |
Was crusin down the freeway when I heard something and then ran over something. After coming out of the store I decided to look at the truck to try and figure out what I ran over and if there was any damage. Well I found this. Seems like I ran over it also. I think something flew up from the car in front of me. At least I have an extra. I am just happy it didn't hit my hood or grill.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
04-09-2016, 09:52 PM | #2206 |
Finished passenger door for all new weatherstrip, vent window included. Drivers door is 3/4 finished. This was one of those jobs that took a boatload of time but if I was to do it again, I could literally do it in 1/4 of the time. One of them jobs u think back on and can't imagine you had so many hours in it. Oh well.
04-09-2016, 11:18 PM | #2207 |
Painter sent me a photo of my newly installed trim around the windows. Also first sighting of bed on the truck.
04-10-2016, 12:03 AM | #2208 |
04-10-2016, 12:09 AM | #2209 |
Put my 64 GMC on a lift today and greased the front end, and also repaired an almost melted electric fuel pump wire....I don't think wires like sitting on exhaust pipes....few zip ties and That problem was solved. EDIT. Yes I replaced the wire.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-10-2016, 12:53 AM | #2210 |
i finished the fabrication of my center console and the upholstery shop finally got my Katzkin seat covers on the new seats...
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 Last edited by par4tom; 04-10-2016 at 01:01 AM. |
04-10-2016, 11:57 AM | #2211 |
Got the top half the cab sprayed yesterday. Hopefully the inside and rest of outside by the end of the week.
04-10-2016, 05:02 PM | #2212 |
Got my auto box painted then fitted a new filter and sump pan
I flipped it over and fitted the new filter . The old style filter The new one fitted New sump fitted and I also fitted a Ron Francis Transmission Neutral Safety Switch
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
04-11-2016, 10:16 PM | #2213 |
Brake line work today. Did the rear axle and then worked on plumbing in for the dual MC on Goldie.
KippnIdaho Twin Lakes, Idaho 1966 K10 SWB Stepside 2003 Jeep Rubicon 2011 Camaro SS Rag Top |
04-11-2016, 11:33 PM | #2214 |
finishing up the chassis for JB'S 65 truck , so that I can get started on the cab .
04-13-2016, 02:44 PM | #2215 |
Driver's side disc brake conversion on 2.5" drop spindles, new shock and cleaned/painted controls arms. Wife made me stop last night at 1145pm when she could hear me banging the ball joints loose on the passenger side spindles from the house, whoops!
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
04-13-2016, 02:52 PM | #2216 | |
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
04-13-2016, 04:23 PM | #2217 |
Moderator
04-13-2016, 07:25 PM | #2218 |
Got the inside of the cab block sanded. Be wet sanding Friday.
04-16-2016, 03:30 PM | #2219 |
Finished spraying the cab today.
04-16-2016, 06:52 PM | #2220 |
Did a little wiring clean up & found out the new ignition key from my aaw kit will lock my drivers door but not the passenger door which is great because the truck didn't come with a key lol
04-16-2016, 11:37 PM | #2221 |
Installed the new 572 in me an dad's 77.
04-17-2016, 04:33 PM | #2222 |
We got the bed on. Took us about 4 hours to tweak the bed and cab bolts so the lines were just right. Will rethink the next two tone.....
http://s1299.photobucket.com/user/jb...23904108567829 |
04-17-2016, 07:13 PM | #2223 |
Moderator
Pulled the left rear leaking wheel cylinder. Decided to do the rear pair... happy I checked, the right side was just as bad, just not leaking out the bottom of the drum yet. I'll order new ones tomorrow! It will be nice to have working brakes again. I should fix my parking brake...
04-17-2016, 08:50 PM | #2224 |
Made my truck more useless, hahaha. -Jimmy-
NOMADSC.C. |
04-18-2016, 01:09 AM | #2225 |
Got to doing some minor bodywork, repaired small rust spots on passenger's door. Installed two Flowmaster Delta 44's (1960, rebuilt 350 and turbo 400....both have 430 miles on them). Getting ready to paint her in a week or two. Ordered my wide whitewalls, they should be installed this Wednesday.
