Why's everybody hatin' on the 305?
I notice that the first thing a C10 buyer on here often does when he gets a new project truck is to yank the 305 out of it.
Now I understand that the 305 isn't the path to power. But isn't it a serviceable engine for a daily driver? Is anyone here using one for that, or is a 350 the minimum acceptable SBC? #tryingtounderstand |
Re: Why's everybody hatin' on the 305?
I'm running a 305 in mine. Have zero interest in swapping it out.
If you're replacing the engine anyhow it makes sense, but swapping it out just because is a lot of work for not a lot of difference. |
#3 | |
If I were to purchase a truck that needed NOTHING and had a 305 in it, I would likely drive it until the engine needed attention, THEN replace it with a 350... but since its basically the same price to rebuild a 350 than a 305, replacing a tired engine with an upgrade is a no-brainer. I have read article on building STRONG 350+HP 305's... but at the end they always tell you the same money would build a much better 350...
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
I had a 305, decent enough engine, ran it for years towing cars and daily driving. Hopped it up a bit with an RV cam, longtube headers. I did end up swapping it out for a 5.3L last year because I couldn't get the tune nailed down for the TPI, and just wouldn't run right. Needed it reliable for Home Depot runs and whatnot. The 305 sitting under my bench now waiting for something to drop it in, tuning issues with ancient ECMs aside, it's a strong runner.
They're adequate, but not worth building with how cheap a 350 can be had for.
That said, if I was building an engine for anything more than a basic A to B work truck, I wouldn't go 350 either - I'd go bigger.
1973 C20, 350/350 |
Ive got a 305 in my truck. Being that I have a computer controlled carb and ignition and living in California there is only so much I can do. Going to a 350 requires a different PROM for the ECM. My truck has pretty decent power for what it is. Its my only vehicle so I cant go too crazy anyway. I plan to do a 350 swap at some point but the little 305 does pretty good and gets decent mileage. Some better gears would really wake this thing up.
Anthony |
#8 | |
driving is in my blood
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
If you've got a 305 you should plan on replacing the cam around 70K miles.
I had one in a 1977 Impala and loved it. If tunes right it gave some 350s a run for their money. RIZ |
In a truck Id rather have a 305. The longer stroke makes better torque. True the small bore hurts max power but for a daily driver the 305 does just fine. And plenty of people drive these old trucls daily. My 85 GMC is the only vehicle I own so it is my daily driver for sure.
Anthony |
![]() Join Date: Nov 2015
I had a 305 in a 1977 Camaro...not a problem with it and it ran good and strong...just sayin'...Marla
have a 305 in my daily (60 miles round trip) but I'll be swapping to a LS motor soon I think. I have the sm465 trans, and mated with the 305 in the mtn traffic is not the best when I shift into 2nd and everyone behind is giving me the finger
#13 | ||
I'm not sure I'd want a 400 crank though, 3.75" results in a lot of wall loading. If I did have one, I'd go with the longest rods I could. I might be more inclined to go 377 (3.48" stroke, 4.125" bore).
1973 C20, 350/350 |
#14 | |
Cruzzzn' Vet
![]() http://arb.ca.gov/msprog/aftermkt/de...o/D-126-30.pdf |
#15 |
I bought a new K-10 in 1982 with the 305 engine in it.Couldn't get a 350 in a 1/2 ton truck in 82.
I put 200,000 plus miles on it before the compression rings wore out.Did not burn oil or smoke.Just wouldn't pull anymore! I have a 305 in my 68,c-10 now until I get the 327 rebuilt and it runs great. Excellant engine for a daily driver and you can buy one for much less than a 350. Mike. ![]() |
#16 |
Not a thing wrong with the 305 - but like you're starting to see - if you're going for performance, it doesn't make sense to build the 305.
Reliability, towing, etc? Sure, nothing at all wrong. My 84 still has the 305 and I plan to drive it until it grenades. And the truck used to pull a small camper back in the day with no issues. If you have it, and it runs fine, use what you have. If you want to make impressive numbers at a dyno or a race track... you might want to upgrade the engine to a 350 (cheapest route) first.
Current Projects: 1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion 1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently. |
#17 |
If your building for more power or top power 350 0r go 383-400.
But I went from 454 to 305 to save fuel Because I could use most 350 parts part stash, 305 get better fuel economy heads & exhaust manifolds.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#18 |
had several 305s back when they were common.
As I recall they were bad about clattering. Not great on power, nor fuel mileage. Never was a fan. |
#19 |
My 85 still has the numbers matching 305. Runs good and strong. Its still a small block chevy and I would rather have a 305 than any strait 6, 4.3 v6 or crappy diesels that came in C10's. However, If the 305 in my truck grenades, I will swap in a Goodwrench 350.
#20 | ||
The 3.75 stroke may put more load on the cylinder walls but it in no way means its got less longevity. Especially is you use longer rods to take that load off of the cylinder wall. The 305 has a bad reputation similar to how the 396 bbc did. People see it as a small engine that costs the same or more than the bigger counter parts. That does not mean they cant work well. On the 3rd gen camaro site there are plenty of guys with mild 305`s knocking on the 12 second door. Quote:
Thats funny because I have been eyeballing that same exact set up for my 85. Now that I had a knowledgeable guy rebuild my E4ME carb and got my mixture control solenoid working the truck runs good and has some pep to it. It feels as strong as my old 90 K5 blazer with a TBI 350. Getting about the same mileage too.
Anthony |
#21 |
Why can you make a 4x3 Ford engine work well in a truck (they were in LOTS of them) but not a 4x3 Chevy engine?
Stroke is far less important than heads/cam, and Chevy 302s tend to have big heads/cam resulting in minimal bottom end. People don't tend to bild them for grunt either, as they tend to go bigger in that case, but they can be.
1973 C20, 350/350 |
#22 | |
And the 302 engine engines came stock with the same 165cc heads as all the other sbc engines such with at least 300hp. They were nothing special by any means. And they have big cams because you have to review the crap out of them to make the power because the short stroke lacks low end power. Given the same heads, cam and compression my money is on the 305 for more low end power. And stroke is every bit as important as the rest of the combo. Any problems builder will tell you that ALL parts need to work with each other.
Anthony |
#23 |
Stroke isn't particularly important other than the displacement it provides. Put 305 heads/cam on a 302 and you'd have very similar performance to a 305.
More displacement absolutely helps torque, and if you aren't spinning faster than a 350 can there isn't much reason to go with a 302 instead (other than class limits). Since they were no longer building homologation cars, there wasn't much reason to build a 302.
1973 C20, 350/350 |
#24 |
This is incorrect information. Go run that past your favorite engine builder and let us know what he says. The difference in bore and stroke would create 2 completely different power bands from a 302 and a 305. And I dont recall anyone suggestion to the OP to build a 302 I stead of keeping his 305.
Anthony |
#25 |
As just a daily driver the 305 is a prefect engine.If you want to build a nasty engine then i would swap it for something else.
