Old 04-07-2016, 08:50 AM   #1
Isaiah92260
Isaiah92260's Avatar
Problem shifting, keeps binding up
I just replaced the upper bearing on my steering shaft. But once I got the steering wheel back on, my 3 on the tree binds up when I try to shift it into reverse and 1st. I have to lift the hood and go push back the 1st and 2nd lever back down...It's almost like it worked better when I had the worn out bearing on it. I just got the 63 shop manual but it doesn't really explain much about this, unless I'm not looking right. If anyone has more experience with the 3 speed please share some light, thank you !
Isaiah92260 is offline   Reply With Quote
Old 04-07-2016, 09:15 AM   #2
Fla Grown
Fla Grown's Avatar
Re: Problem shifting, keeps binding up
https://www.youtube.com/watch?v=2TCHzIvAvRQ
Check out this video. I just adjusted mine and everything is working properly.
Fla Grown is offline   Reply With Quote
Old 04-07-2016, 10:36 AM   #3
GRX
GRX's Avatar
3 Speed Manual Column Shifter Adjustment
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 04-07-2016, 07:22 PM   #4
Isaiah92260
Thank you for all of the helpful links..... I still one problem I can't figure out. When I attempt to go into 2nd and reverse, I noticed that the selector doesn't move. It just want to stay on the 1st and reverse leave. Why is that?
Old 04-07-2016, 08:37 PM   #5
Isaiah92260
So here is the problem I have. The shifting Houston. Maxes out when it butts up against the round washer/Mast. Seems like when I push forward towards the dash to grab the 2nd/3rd gear. The housing butts up like I said and won't allow me to move the shaft that handles the selector at the bottom. This doesn't make sense to me, it work fine before I took off the steering wheel. I have all the hardware all together and made sure that I put everything back right.... I'm not sure if there is something I am missing.
Old 04-07-2016, 08:39 PM   #6
Isaiah92260
Is it because my lever is work out and old?
Old 04-07-2016, 08:43 PM   #7
Isaiah92260
I know it's hard to see but, at the end, that's where it stops agains that round washer that also bolts on the bottom, do I have it backwards and have to flip it around so that it sits further in the shaft? Because where it bolts down, it sits off set.
