Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-07-2016, 04:53 PM   #1
oem4me
WANTED: Orig 66 TH400 dipstick.
The end of my trans filler dipstick broke off at the kink. Luckily, the end piece flaked off just after I extracted it from the tube. Now I'm looking for an original/correct one in good shape.
Old 04-08-2016, 11:17 PM   #2
aotte1
Re: WANTED: Orig 66 TH400 dipstick.
Can you post photo of the one you need? Application is SBC?
This is a common problem, often they crack and leak.
Les
aotte1 is offline   Reply With Quote
Old 04-09-2016, 01:35 AM   #3
wfojon
Chevy guy
Why do they do that? Mine is broke off too and unfortunately is sitting in the bottom of the tube in the transmission. I guess I will drop the pan and retrieve it and find me a new dipstick.
wfojon is offline   Reply With Quote
Old 04-09-2016, 01:41 PM   #4
notsolo
notsolo's Avatar
Not sure about the year! I believe it was 67 or older 26 1/2" long (Top ring to tip). I will try for better photo's if this looks close...Ed
notsolo is offline   Reply With Quote
Old 04-09-2016, 03:27 PM   #5
oem4me
Les
Im away from home and can't get to my truck today. I'll do it ASAP. Thanks.
Old 04-10-2016, 08:48 PM   #6
aotte1
They crack and/or break because of vibration. The metal develops stress cracks, then failure. Probably the wrong type of metal was used.
Les
Old 04-11-2016, 01:40 PM   #7
oem4me
Here's the subject dipstick. 23-1/4" inches from stop to end. I didn't measure the handle, but it's about 3" or a little more.
Old 04-11-2016, 08:01 PM   #8
60-66
60-66's Avatar
Heres an NOS one Bruce so you can compare GM Part number. Original number was 3905449 changed to 1387568 and again to 1239014
http://www.ebay.com/itm/NOS-1968-73-...ZWeEGb&vxp=mtr
http://www.ebay.com/itm/NOS-1968-197...1UREK4&vxp=mtr
They are the same as Cars with TH400 so I have several extras used if you need one
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-12-2016, 10:36 AM   #9
oem4me
Thanks for the info, Jon. Message coming.
Old 04-12-2016, 10:40 AM   #10
oem4me
Thanks for the early response. So, that stick looks like it's an inch longer than mine from the stop to end, right? (23-1/4")
Old 04-12-2016, 12:38 PM   #11
notsolo
notsolo's Avatar
Bottom of stopper to tip 23 5/8...Top of metal cap over stopper to tip 24 7/16.....$48.00 for the whole thing tube and dipstick...Ed
Old 04-12-2016, 03:28 PM   #12
oem4me
Fractions of inches matter on this, agree? Just making sure.
Why's it look more like 24-5/8 in the photo? Thanks
Old 04-12-2016, 04:22 PM   #13
notsolo
notsolo's Avatar
Photo's distorted, cloth tape to give you rough idea! More recent measurements are with a steel tape. Can mic the width and thickness if you want. Also some minor surface rust pitting front and back.
Old 04-13-2016, 03:10 PM   #14
oem4me
Great, So helpful! ..While you are at it, would you mind weighing it and having some filings analyzed for carbon content? Just kidding. I found one. Thanks anyway. Cheers!
