04-10-2016, 08:56 AM | #1 |
Tranny ID help
I am trying to find out what model and year my 3 speed in my 55 is. It is not the original trans. I know it is a muncie by comparing it with pictures on the net. casting number on right side of case is 3911982, the last 3 might be 882 the eight and nine look about the same. Any body out there got any books on these?
04-10-2016, 11:37 AM | #2 |
Hollister Road Co.
Re: Tranny ID help
post a picture of the whole trans
04-10-2016, 02:09 PM | #3 |
Re: Tranny ID help
C 17 ? March 17 of what ever year the last digit is, should be 5 if original to the truck.
04-10-2016, 02:41 PM | #4 |
04-10-2016, 03:12 PM | #5 |
Re: Tranny ID help
3 speed ? 4 Speed or ?
If a 3 speed how many bolts on the side cover? I did find reference to that casting number but no real info on it.
04-10-2016, 04:40 PM | #6 |
Re: Tranny ID help
more pictures,best I could get laying under truck last number of date code seems to be an 8 it is a 3 speed.
04-10-2016, 04:57 PM | #7 |
Hollister Road Co.
Re: Tranny ID help
Its a Mid 60's Saginaw HD 3 speed. They used it behind 396 and others of that era in Camaro's and chevelles
04-10-2016, 07:40 PM | #8 |
Re: Tranny ID help
OK thank you I need to find some parts and this helps
04-11-2016, 12:37 AM | #9 |
Re: Tranny ID help
I have not been able to find that PN, but the 8 could indicate 1968 or 58. I did find that in 1966 1st gear became synchronized so you could shift into first gear without double clutching or coming to a complete stop. If it is the HD model will have an 1.125" input shaft. Stout unit, used in roundy car racing.
04-11-2016, 11:04 AM | #10 | |
Re: Tranny ID help
04-11-2016, 01:02 PM | #11 |
Re: Tranny ID help
Good thing is they don't need parts too often unless you really abuse them. I've got one in my 48 that has been trouble free for a lot of miles.
04-11-2016, 03:27 PM | #12 |
Re: Tranny ID help
If 1st gear is syncroed it is worth fixing
04-11-2016, 05:29 PM | #13 |
Re: Tranny ID help
yes first gear is syncro, I really only need the speedo drive gear and shifter shaft seals I might crawl around under it tonight and look for more numbers
04-11-2016, 07:43 PM | #14 |
Re: Tranny ID help
Those parts shouldn't be too hard to find. IIRC they're similar to Saginaw 4 spd parts.
04-12-2016, 03:50 PM | #15 |
Re: Tranny ID help
I'd try Garage Motorsports, Vancouver, WA for your parts. They have a lot of trans. parts, ask for a guy named Mike, very helpful and knowledgeable. Web search their name and it will come right up. Good Luck.
2018 BMW R1200RT 2013 Aprilia Tuono 2012 Ford Flex 2011 Ducati Hypermotard 1959 Chevy 3100 |
04-13-2016, 01:13 PM | #16 |
Re: Tranny ID help
This is a great forum. I can't offer any assistance but did get one of my questions answered. It looks like you can use a transmission like this where there is no rear mount. I want to find an all syncro three speed but was concerned about only mounting it with the four bolts in the front. It looks like that is how Virginian's is mounted so apparently it is OK to do it. Excuse the "sidetrack".
04-14-2016, 12:20 AM | #17 |
Re: Tranny ID help
A cast iron case & cast iron bell housing will work with the four bolts on the case
My Tremac is mounted to a cast iron bell housing with just the 4 case bolts
04-14-2016, 06:22 PM | #18 |
Re: Tranny ID help
Thanks for the info, I was hoping that was the answer.
