04-13-2016, 10:24 AM | #1 |
Water Pump Pulley Help Please
On our 86-91 BBC trucks the alternator belt is a serpentine belt. I was wondering if anyone has the part numbers for the water pump pulley that also has the single v-belt groove as well? Im trying to convert my Pro-Street BBC over to this to ease my charging issue. Pic of setup For reference..
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
04-15-2016, 10:18 PM | #2 |
Re: Water Pump Pulley Help Please
Your is mostly like a 7 in pulley water pump. 69-72 there to ID: #'s BB 7" 33956666 ID: #'s SB 7" 330556 single grove.
V8 73-77 single grove water pump 7" ID:# 14023154 CC hope this helps
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
04-15-2016, 10:42 PM | #3 |
I have the later model long nose pump and currently have a double groove v-belt pulley. What I'm wanting to do is keep the double groove but make the alternator a serpantine belt like the 86-91 motors have. If that makes sense.
04-15-2016, 10:49 PM | #4 |
This is a pic of my setup but it has a cs130 amp now and has been rewired.
04-15-2016, 11:24 PM | #5 |
Ok so you have serpentine belt. on the out side, but you have a two belt pulley on the water.
If I got this right now. You want a serpentine belt on the out side of the water pump pulley and a in side V belt. Wright Then you are looking for the 84-86 Firebirds / Camaro could be the V6 305-350 set up. I got one of these for my 76 Lemans . NOT Know the #'s on them of hand not sure where I put it to look at them. Think the Monto Carlo had this set up to but can't remember what year and what motor set up.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 04-15-2016 at 11:31 PM. |
04-15-2016, 11:35 PM | #6 |
LINK: https://marchperformance.com/aluminu...mp-pulley.html
This might be the one your looking for?
04-15-2016, 11:38 PM | #7 | |
04-15-2016, 11:43 PM | #8 | |
04-16-2016, 08:11 AM | #9 |
Try to look in the scrap yards junk yards for the 84-86 Firebirds / Camaro could be the V6 305-350 they have the set like this if you find one grab alt or ( just the alt Pulley ) if you have a Batt impact gun, water pump pulley, belt or mark down the size, keep eye on e-Bay for them.
