04-13-2016, 11:19 AM | #3526 |
Re: What did you do to your truck today? Chapter II
Went to take my daughter for a ride this weekend, engine turned over, and then starter wasn't turning the flex plate. Looked under the truck and found this. Seems to be a common problem with the aftermarket PMGR starters. Tried installing a replacement from Napa and it was bad out of the box so I spent $3.60 on 3 new machine screws to mount the starter to the mounting flange (thanks to some great comments on the Summit site). I'm really glad this happened in my driveway and not 60 miles from home!
Shawn G. 1969 C20 |
04-13-2016, 11:19 AM | #3527 | |
04-13-2016, 10:24 PM | #3528 |
Getting ready to start the rust repair, removed the bed today at work. Drove it home about 8 miles on the city streets with my make shift tail lights. Fully functional of course.
04-14-2016, 07:21 PM | #3529 |
Old member
I added some lights to mine!
One on each door.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-14-2016, 09:58 PM | #3530 |
I broke it.
On the way home from work, I heard a hissing sound, and soon the power steering wasn't. Popped the hood to find the expected spray of fluid in the front left corner. I man-handled him home, and now I have to refill the pump to see where the leak is. I *think* its a hose and *hope-and-pray* it's not the box.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
04-14-2016, 10:02 PM | #3531 |
Got a call from the woman to tell me I have 5 big boxes sitting in the living room waiting on me to get home this weekend...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
04-14-2016, 10:16 PM | #3532 |
Bought some new shocks to install this coming week
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-14-2016, 10:38 PM | #3533 |
When I could not get enough hood to fender gap(on passenger side) with my aftermarket hood,decent gap on driver's side I put a hopeful ad on Craigslist.Jim not only had an hood in excellent shape but drove over an hour to deliver it,so I learned that when you get disgusted and don't know what to do next---it is going to work out.
04-14-2016, 11:10 PM | #3534 |
Finally got brake fluid squirting from all four corners on my K10. Found the rear flex line had collapsed inside--likely original. Some more bleeding to do to get it right as the master cover (rebuilt unit) leaked so I used the old one.
Also installed the new glove box insert and will be doing the door and window seals as well as some other small items. Pertronix is next..... |
04-15-2016, 05:31 AM | #3535 |
That is cool! I have never seen that done before.
Brad handshoe |
04-15-2016, 07:46 AM | #3536 |
That is way cool. One of the best lighting mods I have ever seen.
04-15-2016, 12:03 PM | #3537 |
04-15-2016, 03:35 PM | #3538 |
Old member
You drill a hole in the bottom of the door and run the hot wire to a constant 12 volts. Then the ground to the door jam ground so when you shut the door it turns off. The flash washed it out.
I bought them off E Bay! Here is his add. Takes about a week and half to get them. http://www.ebay.com/itm/LED-Lighting...658017?vxp=mtr
04-15-2016, 03:40 PM | #3539 | |
I see now pretty cool. Thanks I got a lot more to do before I get to those details. But nice. |
04-16-2016, 10:50 AM | #3540 |
Hey guys!
I just made a post on the thread about my truck; http://67-72chevytrucks.com/vboard/s...=1#post7562538 I will get more photos soon! |
04-16-2016, 11:41 AM | #3541 |
Started the tear down, no big surprises yet. The speaker holes behind the seat really irritate me. Need to get the fuel tank out and weld in some braces.
04-16-2016, 09:42 PM | #3542 |
Yesterday, I took a broken header off. Today, I put one new one in, along with replacing the fuel pump and filter. (There's nothing like getting a gasoline bath right before supper!). Tomorrow, finish up the other header and put a new temp sending unit in. Pretty fruitful weekend, so far
04-17-2016, 08:25 PM | #3543 |
Fit the new grille, mocked up some radiator brackets, and sat the bed back on the frame to get an idea on how Im going to do the fuel fill with the Boyd tank and stripped the driver side of the bed and uncovered quite a bit of work its gonna take to get it straight. No rust hidden under all that paint and bondo though.
04-17-2016, 08:40 PM | #3544 |
Got the headers finished, temp sender in, and one wheelwell. I'll finish it up tomorrow. Still have to replace some fuel line. Sorry for the blurry pic. Next week I'll start on the inside. I'll keep y'all posted
04-17-2016, 09:05 PM | #3545 |
Got the final block done on the cab of "Raymond... moving to the bed this week... Hoping to go to paint with the cab and bed next weekend...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 Last edited by Elliot949; 04-17-2016 at 10:42 PM. |
04-17-2016, 10:37 PM | #3546 |
Got to take mine on a road test and drove it about 120 miles to San Antonio.
I finished my transmission swap about two weeks ago and I'm loving the overdrive. I put a 200-4r in and cruise at about 2250 rpm to do 75 mph. Glad to be able to drive it again as it has been down for about 3 1/2 years. |
04-17-2016, 11:32 PM | #3547 | |
Congrats on getting yours back on the road.
04-17-2016, 11:34 PM | #3548 |
I have a 3.73 with 30x9.50x15 tires
Thanks it's great to drive it again |
04-17-2016, 11:42 PM | #3549 |
Installing Vintage AC in the Blazer. Good AC is a must have for the Power Tour.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
04-18-2016, 08:49 PM | #3550 |
Hootis is as Hootis does...
3" Exhaust Install - Future SuperCharger....
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires 1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires 1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires |
