04-15-2016, 11:27 PM | #1 |
Question, 1981 and 1985 sheet metal interchangeable?
I just got home with an 85 Stepside that needs a few things. I have a nice 81, 3/4 ton donor truck. Same stuff?
Thanks |
04-15-2016, 11:56 PM | #2 |
Re: Question, 1981 and 1985 sheet metal interchangeable?
Yep
John '91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's |
04-16-2016, 03:12 AM | #3 |
Yeah they are the same.
04-16-2016, 10:33 AM | #4 |
Excellent! Thank you
04-18-2016, 09:04 AM | #5 |
As I'm doing some homework I noticed in some pictures that the 85 Chevy seems to have 2 different front ends, a single headlight with turn signal below the the light and double headlights, one on top of the other. What option or package made the difference?
Thanks |
04-18-2016, 10:01 AM | #6 |
I believe the single lights was the lower trim options trucks while the duals was the higher trim trucks.
04-18-2016, 12:06 PM | #7 | |
The base grille single headlamp version was Custom Deluxe and Scottsdale (Z62). You could add V22 (dual headlamps) to a Scottsdale if you wanted - which is what I always did. Uplevel grille was included with the Silverado (YE9) package. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-18-2016, 12:15 PM | #8 |
Many thanks Keith!
...the guru has spoken |
04-19-2016, 11:39 AM | #9 |
You are welcome. You happened to ask one I knew (or remembered) the answer to!
K
