Old 04-18-2016, 12:27 AM   #1
joeydurango
joeydurango's Avatar
Removing left-upper 4x4 ball joint without removing steering arm?
Doing ball joints (and bearings, and hub/spindle seals, and axle shaft seals, and on ad nauseum) on my K10. First time at this, but no problems... until I got to the last ball joint, the driver-side upper. The tool doesn't fit between the steering arm and the ball joint, so the steering arm has to come off. So far, that ain't happenin'. I have tried copious amounts of PB Blaster (otherwise known as the brain-cell killer), SeeTen's socket trick, and of course a BFH.
So I began thinking (always dangerous, I know) - work smarter, not harder. Instead of beating the crap out of the steering arm with a sledge, how else could I press out the joint? The immediate and easiest idea is to modify the receiving tube on the press to be a "C" shape, cut out where the steering arm is in the way. But that leaves me with a very expensive adapter kit that I'd prefer to return to Autozone.
I wondered if any of you have ever come up with a good solution. Removing the steering arm just to press out a ball joint seems like a waste of time and energy. All you really need is some strong, U-shaped piece of metal to act as a partial receiver tube for the joint. I'll keep working on a (cheap) method, but if anyone's got an idea or done this before, say the word.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 04-18-2016, 07:24 AM   #2
Re: Removing left-upper 4x4 ball joint without removing steering arm?
I disconnect the tie rod so the knuckle can swing out to where I can hit it with a good swing. Those little cones will work their way up. Just have to get a better smack on it. Heat will also help
Old 04-18-2016, 08:36 AM   #3
joeydurango
Well, unfortunately I already removed the knuckle from the truck. Didn't think about having to remove the steering arm until I went to press out the joint. Good thing is I can clamp it in my vice... the bad thing is that I can then destroy my bench hammering on the part clamped in the vice.
Old 04-19-2016, 08:55 PM   #4
joeydurango
Well, I did it. For anyone searching for this same thing in the future: Go to the hardware store, and buy a 2" galvanized pipe nipple 3-4" long. Four bucks and that's all you need, and it is the right inner diameter to accept the ball joint. Put the nipple in the vice, take a hacksaw to it, ending up with a "C" shape. Mark it first so you take off only what's needed where the steering arm is too close to the joint to fit a tool. Then use the new C you just made with a press and presto! Super easy, way easier than fighting with the steering arm. Hope this helps someone later!
Old 09-13-2024, 03:55 PM   #5
ohboy321
ohboy321's Avatar
Thank you joeydurango for a great idea. I was using heat and a big hammer and was not making any progress getting the steering arm off. I briefly considered grinding a piece out of my new less than 24 hrs old ball joint tool, but decided to search the forum for any suggestions instead.
With inflation the 2" x 4" nipple costs me $6.98, almost double what you paid 8 years ago. Worth every penny. I used a cut off wheel to make the cuts needed.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 09-14-2024, 07:13 AM   #6
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Removing left-upper 4x4 ball joint without removing steering arm?
I recently did this job on my 1970 Blazer, and rented the Autozone ball joint tool. I was able to remove and replace the LH upper ball joint without removing the arm, damage to the tool, or resorting to making tools. I don't remember any drama. The knuckle was a dry Arizona part, so it came apart super easy. I used NOS GM ball joints, and it went back together effortlessly.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 09-16-2024, 10:30 AM   #7
MJN
MJN's Avatar
Yep- with the correct ball joint tool and adapters this job is a breeze. I think the OTC ball joint press and adapters I bought years ago was probably one of the best tools I ever bought. Also works perfect for U Joints.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
