Old 04-18-2016, 09:06 AM   #76
lowrodderchev
lowrodderchev's Avatar
Re: LS swap for my 75
Things are going little slow. Mainly missing parts and a few other things. Broke a intake bolt, power steering pump gave me trouble. But other than that she's in the truck. Figured since I pulled the motor I would replace my rusted out fenders to
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 04-18-2016, 09:09 AM   #77
lowrodderchev
Even if I didn't get my truck done in a week glad I got to hang out with my best friend ��
Old 04-18-2016, 10:02 AM   #78
68Timber
I know the pieces fit
68Timber's Avatar
Sweet!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-18-2016, 10:07 PM   #79
lowrodderchev
So I got ahold of this 3/4 ton driveline to replace my 203 driveline. If I shorten will I be good? Or is it to beefy? Lol
Old 04-20-2016, 09:28 PM   #80
lowrodderchev
Buddy of mine bead plastic my exhaust and cleared my heat shields Name:  WP_20160420_004.jpg
Old 04-22-2016, 02:49 PM   #81
Ski-me
Ski-me's Avatar
Nice job on Exhaust!
You'll have to really inspect the u-joints or you may want to just change them out as a precaution. Talk to the driveline shop and see how much they would charge to swap them out or you do it, and then bring to shop for shortening/balancing.
Spicer joints
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 04-22-2016, 03:47 PM   #82
lowrodderchev
oh yeah that's the plan new u joints either way. figure everything else is new. First C10 shot me some info on were do get the spline yoke gasket. tomorrow evening I'm going to work on new u joints on both front and back drivelines
Old 04-24-2016, 12:23 PM   #83
lowrodderchev
I just thought about it last night but can I even shorten this driveline? I need to cut off a few feet. I wasn't sure if its possible because its tapered
Old 04-24-2016, 12:40 PM   #84
lowrodderchev
also took a cruise this morning to pick up my wiring looks good cant wait to put it on. to bad I gotta work today
Old 04-26-2016, 08:36 AM   #85
oltronj
Looks like a good project. Been thinking about doing an LS swap on my 90 Suburban. Lots of good info here.
oltronj is offline   Reply With Quote
Old 04-27-2016, 01:42 AM   #86
lowrodderchev
When it rains it pours . My slip yoke has a crack in it lol FML
Old 04-27-2016, 09:18 AM   #87
68Timber
68Timber's Avatar
Ouch. Good that you caught it tho.
John
74 Honda Z50 build
Old 04-27-2016, 09:33 AM   #88
lowrodderchev
Yeah my buddy sand blasted for me and he notice it. Anyone know if I could use this for my rear? It came off the front just want to use the double shaft at the yoke like they did on the pic
Name:  C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_attachment.jpg
Old 05-04-2016, 12:13 PM   #89
lowrodderchev
what a week. so still buttoning up things but seems like it isn't going to good. I'm wishing I would have stuck with a 350. took my front driveline in today to get new u joints. I would normally do it but I don't have the tools to melt out the plastic clips that hold it in. anyways $150to install 2 splicer u joints OUCH. I still gotta take him my rear shaft to shorten ($95) plus new u joints for that. took my radiator in today just to check it guy suggested I just get a new one since that one is original. he quoted me $350 for a new one. any suggestion on were to buy a nice one? thanx
Old 05-04-2016, 01:34 PM   #90
68Timber
68Timber's Avatar
$350 might be a fair price if it's his premium radiator. That's in line with prices I've checked for mine at rock auto for their best. The Champion aluminum radiators are much cheaper but it seems like everyone has to massage the mounts to make them fit. Maybe I let that mess with my ocd more than I should though. Keep after it, you're almost there.
John
74 Honda Z50 build
Old 05-04-2016, 01:54 PM   #91
Front Range
Front Range's Avatar
Originally Posted by lowrodderchev View Post
....just want to use the double shaft at the yoke like they did on the pic
Attachment 1527079
That's the rear shaft in my 87 Burb, had it built. You probably already know this but if you use a double cardan it is recommended that you have no angle (Zero Degrees) at the axle pinion.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 05-05-2016, 10:49 PM   #92
lowrodderchev
No I didn't but its good to know. I'm taking my rear driveline in tomorrow see how it hoes crossing my fingers
Old 05-05-2016, 11:11 PM   #93
lowrodderchev
What's a thread without pix. Painted my front radiator support pieces
Old 05-05-2016, 11:16 PM   #94
lowrodderchev
Few undercarriage shots
Old 05-05-2016, 11:19 PM   #95
lowrodderchev
Fuel lines and new tank(yeah I still need to bolt down the fuel lines)
Old 05-05-2016, 11:21 PM   #96
lowrodderchev
The driveline is just a mockup to see how the angle was
Old 05-10-2016, 10:10 PM   #97
lowrodderchev
I'm thinking of starting a website for ls swaps negative side of the coin lol I ordered the wrong radiator its the one called for my truck but its to tall
ATTACH]1531423[/ATTACH]
Old 05-10-2016, 10:13 PM   #98
lowrodderchev
Finally got my drivelines back buuuut lol guy put larger u joints for a newer truck not a 75 blazer with 1310 u joints so tomorrow I gotta shoot the drivelines back to him and well see how long it takes
Old 05-10-2016, 10:19 PM   #99
68Timber
68Timber's Avatar
I don't speak LS very well either, I'd be making those mistakes too. What radiator did you end up going with?
John
74 Honda Z50 build
Old 05-10-2016, 10:49 PM   #100
lowrodderchev
I got a champion radiator pretty nice though just wrong one. There going to swap me out for another one but just one more thing I gotta wait for
