04-21-2016, 09:59 PM | #1 |
Transmission Crossmembers Collect Them All!
remember growing up when those silly action figure commercial would come on and they would show you like 17 of the same thing and at the end say "Collect Them All"
well that's how I am feeling lately hunting for transmission crossmembers while trying to wrap up my manual Overdrive Transmission swap on my beloved '74 but enuff about me lets take a look at the many flavors of Square Body transmission cross members (by the way is it "crossmember" one word, or "cross member" two words?) |
04-21-2016, 10:07 PM | #2 |
Re: Transmission Crossmembers Collect Them All! - 1973 C20
our generation starts in 1973 so it's only appropriate that our first candidates are from 1973
first let me start off by saying I know nothing about automatic transmission, I mean I know there's the 400, 350, 200, and the 700 and I think I already said too much I mean I don't even know how to drive an automatic (that's a joke) so check out this beauty a yellow(ish) 1973 Chayenne Super 20 (now correct me if I is wrong, but the C20 means 3/4 ton, correct? if so just keep that in the back of your head as we bring up the another truck from 1976 later on) so this one had the transmission crossmember mounted to the bottom frame rail, we will call this crossmember a low rise as you will see later on there is one that is a bit taller (aka the high rise) Note: this truck was an automatic, but the transmission was already gone, so we don't know what kind it had so where am I going with this, my point is coming so just keep a readin' Last edited by Gregski; 04-21-2016 at 10:13 PM. |
04-21-2016, 10:20 PM | #3 |
Re: Transmission Crossmembers Collect Them All! - 1974 C10
so here's a look at my old setup, this is a 1974 manual 4 speed the Muncie SM465
this one has a top mounted transmission crossmember |
04-21-2016, 10:24 PM | #4 |
Re: Transmission Crossmembers Collect Them All! - 1976 C20
ok this is where I got confused, how come this C20 aka 3/4 ton truck, also an automatic like the one from 1973 has a different transmission crossmember
yes it is still bottom mounted, however it sits about two inches higher than the one from 1973, I call it the high rise style can you help me identify this transmission, this truck had this trans in it |
04-21-2016, 10:26 PM | #5 |
more / better pics of that 1976 transmission
anything on it screams TH400 or TH350? Edit: just found this Identify My Transmission page, pretty cool, I am leaning on calling it the TH400, ha ha Last edited by Gregski; 04-21-2016 at 10:32 PM. |
04-21-2016, 11:49 PM | #6 |
Looking at the specs on GM Heritage Center there were all sorts of different dimensions for the frame over the years too.
1973 C20, 350/350 |
04-22-2016, 12:03 AM | #7 |
Keep in mind besides the various transmissions used, there were half tons, 3/4 tons, 1 tons, 2 wheel and 4 wheel drive variations, short and long wheelbase too.
That brings the possible combinations up to about a million different ones used.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
04-23-2016, 10:47 AM | #8 | |
the cross member from it should work nicely for your 833
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
04-23-2016, 11:22 AM | #9 |
04-23-2016, 11:30 AM | #10 |
ok, so this is yet another transmission crosssmember that I have, I believe this one came off of a mid 80s automatic 4X4
This one was also mounted on the bottom frame rail so here it is in the original dirty condition as I pulled it off the donor truck, and then squeaky clean, and ready for paint |
04-23-2016, 11:33 AM | #11 |
Re: Transmission Crossmembers Collect Them All! - 1985 C10
and then I saw this one, now this one may be the whackiest of them all, I did not get this one, I sorta forgot to pull it at the Pick n Pull and I sorta didn't want it, ha ha (also it didn't look too safe to pull it - and I didn't wanna get dead)
looks like it is also an automatic crossmember here it is shown on a 1985 C10 doing what can only be described in [ahem] motorcycle terms as a "Stoppie" LOL Last edited by Gregski; 04-23-2016 at 11:40 AM. |
04-23-2016, 11:37 AM | #12 |
this pic of a 1987 crossmember I borrowed from our brothers at 73-87ChevyTrucks.com should be the same as the 1985 automatic above but I just wanted to show you this beauty off the truck
04-23-2016, 05:49 PM | #13 |
Those first two auto x-members you posted are actually the same. The first one is just missing the outer support brackets. I have only ever seen 4 different style trans x-members on these trucks.
73-79 auto, 80-87 auto, 73-79 4x4, 73+?? manual, don't quote me on it though.... Keith Seymore would probably know for sure...
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
04-23-2016, 06:14 PM | #14 |
I'm just speculating, but that last goofy one you posted looks to have only one exhaust pipe headed back, I wonder if that's for the Inline 6.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
04-23-2016, 11:02 PM | #15 | |
hrere are some better comparison pics |
04-24-2016, 07:06 AM | #16 |
Trucks with catalytic converters had 'single hump' cross members. The lead pipes tied together and ran into the single converter, which was hung off a bracket at the cross member. Thus need for pipe clearance was one side only.
There seems to have been a change in the 4x4 cross members at some point, the height of the trans to t-case adapters changed.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
04-24-2016, 11:15 AM | #17 |
A question: My 82 C10 has a crossmember that's high on the drivers side for exhaust pipe clearance, but low on the passenger side. Will a crossmember like the one above fit my truck for more exhaust clearance on the passenger side? Transmission is a TH350.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
04-24-2016, 01:03 PM | #18 | |
but I don't know if there was a big difference in frame design between the 73-80 trucks and the 81-87 trucks so maybe someone else can comment, I always stress that they should have been broken up into two separate eras/generations but no one is listening, ha ha, jk |
